查看: 9539|回复: 1
[求助] 1 怎么改回从emmc启动,2 nfs加载野火的根文件系统出现问题
发表于 2021-10-3 12:36:51 | 显示全部楼层 |阅读模式
1 之前改成了tftp下载内核和设备树,怎么改回从emmc启动。通过野火\3-Debian镜像\ebf_debian_2021_06_08\USB烧录镜像\mfgtools-release烧写后,怎么之前的bootcmd和bootargs都还存在,mfgtools-release不会擦除整个emmc存储区吗,不会的话,我该怎么手动擦除自己之前
设置的uboot中的变量,或者怎么变为默认值?
以下是我通过uboot的命令查看到的,fatls mmc 1:1显示有boot,kernel目录等,但是没有zImage,dtb,导致想通过网上的一般方式手动改为emmc启动不知道怎么弄。
U-Boot 2020.10-00819-g92bbb6711d (Oct 01 2021 - 13:30:45 +0800)
CPU:   Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU:   Industrial temperature grade (-40C to 105C) at 50C
Reset cause: POR
Model: Freescale i.MX6 UltraLiteLite 14x14 EVK Board
Board: MX6ULL 14x14 EVK
DRAM:  512 MiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... OK
In:    serial
Out:   serial
Err:   serial
Net:   Could not get PHY for FEC0: addr 2
eth1: ethernet@20b4000Could not get PHY for FEC0: addr 2
Hit any key to stop autoboot:  0
=> mmc dev 1
switch to partitions #0, OK
mmc1(part 0) is current device
=> fatls mmc 1:1
       38   ID.txt
            kernel/
     2342   uEnv.txt
      611   SOC.sh
            boot/
       34   autorun.inf
4 file(s), 2 dir(s)
=> ext4ls mmc 1:2
<DIR>       4096 .
<DIR>       4096 ..
<DIR>      16384 lost+found
<DIR>       4096 boot
<DIR>       4096 bin
<DIR>       4096 home
<DIR>       4096 tmp
<DIR>       4096 proc
<DIR>       4096 opt
<DIR>       4096 srv
<DIR>       4096 usr
<DIR>       4096 run
<DIR>       4096 mnt
<DIR>       4096 etc
<DIR>       4096 sys
<DIR>       4096 lib
<DIR>       4096 root
<DIR>       4096 var
<DIR>       4096 sbin
<DIR>       4096 media
<DIR>       4096 dev
=> printenv bootcmd
bootcmd=tftp 80800000 zImage; tftp 83000000 imx6ull-mmc-npi.dtb; bootz 80800000 - 83000000
=> setenv bootcmd 'mmc dev 1; fatload mmc 1:1 80800000 zImage; fatload mmc 1:1 83000000 imx6ull-mmc-npi.dtb;bootz 80800000 - 83000000'  //这样不行,fatls mmc 1:1没有zImage和dtb
2 想通过nfs的形式挂载野火的根文件系统,我将野火\3-Debian镜像\ebf_debian_2021_06_08\USB烧录镜像\mfgtools-release\Profiles\Linux\OS Firmware\release\console-armhf-rootfs-lubancat-carp的压缩文件拷贝到虚拟机中
在uboot命令行中设置setenv bootargs ‘console=ttymxc0,115200 root=/dev/nfs rw nfsroot=192.168.3.18:/home/ly/nfs/rootfs,v3 ip=192.168.3.24:192.168.3.18:192.168.3.1:255.255.255.0::eth0ff’
在虚拟机的/home/ly/nfs/目录中新建rootfs,此时出现2种情况,一种是不通过sudo命令操作,一种是通过sudo命令操作,都会出现不同的问题
2.1 mkdir rootfs
      cd rootfs
      tar -xvf console-armhf-rootfs-lubancat-carp
      此时已经解压好了,但是解压显示了一些错误如下:
      ./dev/full
     tar: ./dev/full:无法 mknod: 不允许的操作
     ./dev/fd
     ./dev/tty
     tar: ./dev/tty:无法 mknod: 不允许的操作
    ./dev/random
    tar: ./dev/random:无法 mknod: 不允许的操作
    ./dev/stdout
    ./dev/console
    tar: ./dev/console:无法 mknod: 不允许的操作
   ./dev/zero
   tar: ./dev/zero:无法 mknod: 不允许的操作
   ./dev/shm/
   ./dev/null
    tar: ./dev/null:无法 mknod: 不允许的操作
   ./dev/stderr
   ./dev/pts/
   ./dev/urandom
   tar: ./dev/urandom:无法 mknod: 不允许的操作
   ./dev/ptmx
   tar: ./dev/ptmx:无法 mknod: 不允许的操作
  ./dev/stdin
   tar: 由于前次错误,将以上次的错误状态退出
  先不管,通过重启开发板,可以正常登录,但是操作各种命令,不行,如下:
  embedfire.com Debian Image 2021-06-08
   Support/FAQ: www.firebbs.cn/forum.php
   default username:password is [debian:temppwd]
    npi login: debian
   Password:
   The programs included with the Debian GNU/Linux system are free software;
    the exact distribution terms for each program are described in the
    individual files in /usr/share/doc/*/copyright.
    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
    permitted by applicable law.
    debian@npi:~$
    debian@npi:~$ ls
    bin
    debian@npi:~$ ping 114.114.114.114
    ping: socket: Operation not permitted
   debian@npi:~$ sudo ping 114.114.114.114
   sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
   debian@npi:~$ su -
   Password:
   su: Authentication failure
   debian@npi:~$ su -
   Password:
   su: cannot set groups: Operation not permitted
   debian@npi:~$ su root
   Password:
   debian@npi:~$ ls -l /usr/bin/sudo
   -rwxr-xr-x 1 debian debian 110700 Jan 20  2021 /usr/bin/sudo
   debian@npi:~$
   但是我直接bootargs=console=ttymxc0,115200 root=/dev/mmcblk1p2 rootwait rw也就是从板子的根文件系统启动,都正常,不知道为什么?
2.2 sudo mkdir rootfs
     sudo chmod 777 rootfs
     sudo tar -xvf console-armhf-rootfs-lubancat-carp
      此时已经解压好了,也不会显示不通过sudo的时候的解压错误(也就是上面的解压错误提示)
    此时rootfs显示有个锁的提示
     2.2.1 直接启动开发板,
         npi login: debian
          Password:
        debian@npi:~$
        debian@npi:~$
       PING 114.114.114.114 (114.114.114.114) 56(84) bytes of data.
      64 bytes from 114.114.114.114: icmp_seq=1 ttl=70 time=241 ms
      64 bytes from 114.114.114.114: icmp_seq=2 ttl=88 time=137 ms
    ^C
     --- 114.114.114.114 ping statistics ---
     2 packets transmitted, 2 received, 0% packet loss, time 2ms
    rtt min/avg/max/mdev = 137.112/188.861/240.611/51.751 ms
    debian@npi:~$ ping www.baidu.com
    ^C
    debian@npi:~$ sudo vi /etc/resolv.conf
    [sudo] password for debian:
    # Generated by Connection Manager
    nameserver ::1
    nameserver 127.0.0.1
    此时ping 114.114.114.114可以,也不用加sudo命令,
    但是ping www.baidu.com则不行,我就去改sudo vi /etc/resolv.conf,进去结果这个还改不了,操作没有反应,此时我去到主机的nfs/rootfs目录,想通过主机改sudo vim ./etc/resolv.conf ,结果打开这个文件里面什么也没有
    但是明明在开发板上,如上面几行明明显示有nameserver ::1 nameserver 127.0.0.1,不知道为什么,现在主机里面添加 nameserver 114.114.114.114 nameserver 8.8.8.8,结果显示的时候显示"./etc/resolv.conf" "./etc/resolv.conf" E166: 无法打开并写入链接文件,请按 ENTER 或其        它命令继续,然后网上又搜怎么解决,弄了半天不行
   2.2.2 显示有锁,先sudo chmod 777 -R rootfs/
     然后启动开发板, 现象又和2.1差不多,显示权限不够,
    debian@npi:~$
    然后添加sudo,又显示2.1那种现象
    debian@npi:~$ sudo !!
    debian@npi:~$
难道想用野火的这个根文件系统就不行吗,但是想用。知识有限,搞不懂,搞不懂,整得有点累。各种方法方式都试了,国庆都没有耍,想搞好。
 楼主| 发表于 2021-10-3 12:37:53 | 显示全部楼层
用的是ubuntu-20.04.2.0-desktop-amd64版本
GMT+8, 2024-6-5 09:55 , Processed in 0.026639 second(s), 23 queries , Gzip On.
