查看: 5267|回复: 0
Wallys|IPQ4019 IPQ4029 2.4G/5G Support QCA9880/MT7915 802.11AC support HT...
发表于 2022-10-13 10:23:27 | 显示全部楼层 |阅读模式
Wallys IPQ4019  IPQ4029 2.4G/5G Support MT7915/QCA9880/QCA9882  802.11AC support HTTPS Support all the modules of Quectel
With a history of 10 years, Wallys has been very mature in the design and development of hardware and software in wireless communication. It also supports customization and software development, and has won the trust of 90% of customers around the world and reached a long-term cooperative relationship. It is also a supplier of facebook.
Wallys mainly uses Qualcomm and MTK chips. The main products include router, moudle, industrial access AP and antenna, which are of industrial grade, and the quality and performance fully meet the requirements of users.
The following are the best-selling products of Wallys. Let's take a look at them together. You can contact us at any time if you are in need, or enter our company's official website to check more product information.
Skype/ EMAIL:sales@wallystech.com
DR40x9
Featuring with industrial-grade IPQ4019 /IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Our Firmware supports all the modules of Quectel
Qualcomm IPQ4019 high performance chip solution of wireless router, can support wired network access and LTE network access, support IEEE802.11a/b/g/n/ac protocol, can provide 1200Mbps wireless access speed, fully protect the user network data can be real-time, long-term, stable, efficient transmission, improve user experience. Industrial circuit design, external high-gain smart antenna, can provide better wireless transmission performance, stability and wireless coverage. Excellent appearance design, metal texture, give you a new use experience.
The DR40x9 also supports mini pcie moudle, such as DR900vx (Quaclomm QCA9880 chipset) DR7915 (MTK MT7915 chipset).
2.4G/5G when DR40x9 and DR900vx are working.
When working with DR7915, it supports 2.4G and 5G.
Let's take a look at the introduction and differences between the two cards:
DR900vx
Qualcomm-Atheros  QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE  802.11AC compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Supports Dynamic Frequency Selection (DFS)
FCC,CE and IC Certification
Qualcomm QCA9880 is a highly integrated WLAN SoC that can be used in 5GHz 802.11ac or 2.4/5GHz 802.11n WLAN products. QCA9880 supports 3x3 MIMO and can be used for high-speed wireless data transfer applications. QCA9880 integrates a MAC, PHY, ADC, DAC, 3x3 MIMO wireless transceiver that supports multiple protocols. QCA9880 uses PCI-e interface to communicate with the outside world.
DR7915
MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 20dBm output power
IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
2×2 2.4G & 2×2 5G  MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
SupporttheFrequency2412MHz~2482MHz
SupporttheFrequency5180MHz~5825MHz
Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check  (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
CardsareindividuallycalibratedforQualityAssurance
Mediatek Wi-Fi 6E chipset supports 1024-QAM, OFDMA, TWT, MU-MIMO and other technologies. As the core technologies of the new generation of 802.11ax wireless network (WiFi 6), OFDMA and MU-MIMO can provide multiple concurrent technologies in frequency space and physical space
This is the picture of DR40X9 and DR7915 working. Please feel free to contact me if you have more questions. I am very happy to answer your questions!
GMT+8, 2024-5-15 04:47 , Processed in 0.058903 second(s), 23 queries , Gzip On.
