查看: 243|回复: 0
PWM捕获5路信号错误,求教!
发表于 2019-10-28 15:43:59 | 显示全部楼层 |阅读模式
开了5定时器,5个中断捕获PWM信号时,第3,4信号出错,有没有大神看下哪里有问题!!!
附上代码:
* model_airplane.c
*  Created on: 2019年10月23日
*      Author: mjjol
#include "model_airplane.h"
#include "model_airplane_def.h"
#include "Utility.h"
#include "stm32f4xx_tim.h"
#include "model_airplane_irq.h"
//PA8有干扰,不建议使用, TIM2用于PWM输出,PC9不能用
const PwmInConfigPro PwmInCfg[ModelAirPlaneKeyNum] =
        //高级定时器     Elevator
        {GPIO_Pin_5, GPIOI, RCC_AHB1Periph_GPIOI, GPIO_PinSource5, GPIO_AF_TIM8, TIM_Channel_1,
                TIM8, RCC_APB2Periph_TIM8, TIM8_CC_IRQn, High_Tim},
        //通用定时器     Aileron
        {GPIO_Pin_6, GPIOA, RCC_AHB1Periph_GPIOA, GPIO_PinSource6, GPIO_AF_TIM3, TIM_Channel_1,
                TIM3, RCC_APB1Periph_TIM3, TIM3_IRQn, Normarl_Tim},
        //高级定时器     Throttle
        {GPIO_Pin_0, GPIOA, RCC_AHB1Periph_GPIOA, GPIO_PinSource0, GPIO_AF_TIM5, TIM_Channel_1,
                TIM5, RCC_APB1Periph_TIM5, TIM5_IRQn, Normarl_Tim},
        //高级定时器     Rudder
        {GPIO_Pin_6, GPIOB, RCC_AHB1Periph_GPIOB, GPIO_PinSource6, GPIO_AF_TIM4, TIM_Channel_1,
                TIM4, RCC_APB1Periph_TIM4, TIM4_IRQn, Normarl_Tim},
        //高级定时器     Gear
        {GPIO_Pin_8, GPIOA, RCC_AHB1Periph_GPIOA, GPIO_PinSource8, GPIO_AF_TIM1, TIM_Channel_1,
                TIM1, RCC_APB2Periph_TIM1, TIM1_CC_IRQn, High_Tim},
  * @brief  配置TIM复用输出PWM时用到的I/O
  * @param  无
  * @retval 无
static void TIMx_GPIO_Config(uint32_t RCC_AHB1Periph, GPIO_TypeDef* GPIOx, uint16_t GPIO_PinSource, uint8_t GPIO_AF, uint32_t GPIO_Pin)
    /*定义一个GPIO_InitTypeDef类型的结构体*/
    /*开启LED相关的GPIO外设时钟*/
    RCC_AHB1PeriphClockCmd (RCC_AHB1Periph, ENABLE);
    /* 定时器复用引脚 */
    GPIO_PinAFConfig(GPIOx, GPIO_PinSource, GPIO_AF);
    /* 通用定时器PWM输出引脚 */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin;
    GPIO_Init(GPIOx, &GPIO_InitStructure);
* @brief  高级控制定时器 TIMx,x[1,8]中断优先级配置
* @param  无
* @retval 无
static void TIMx_NVIC_Configuration(uint8_t NVIC_IRQChannel)
   // 设置中断组为0
       // 设置中断来源
   NVIC_InitStructure.NVIC_IRQChannel = NVIC_IRQChannel;
       // 设置抢占优先级
     // 设置子优先级
   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
* 注意:TIM_TimeBaseInitTypeDef结构体里面有5个成员,TIM6和TIM7的寄存器里面只有
* TIM_Prescaler和TIM_Period,所以使用TIM6和TIM7的时候只需初始化这两个成员即可,
* 另外三个成员是通用定时器和高级定时器才有.
* TIM_Prescaler         都有
* TIM_CounterMode           TIMx,x[6,7]没有,其他都有(基本定时器)
* TIM_Period            都有
* TIM_ClockDivision     TIMx,x[6,7]没有,其他都有(基本定时器)
* TIM_RepetitionCounter TIMx,x[1,8]才有(高级定时器)
static void TIM_PWMOUTPUT_Config(void)
    // 开启TIMx_CLK,x[2,3,4,5,12,13,14]
    RCC_APB1PeriphClockCmd(GENERAL_TIM_CLK, ENABLE);
    /* 累计 TIM_Period个后产生一个更新或者中断*/
    //当定时器从0计数到9999,即为10000次,为一个定时周期
    TIM_TimeBaseStructure.TIM_Period = 10000-1;
    // 通用定时器2时钟源TIMxCLK = HCLK/2=90MHz
    // 设定定时器频率为=TIMxCLK/(TIM_Prescaler+1)=100KHz
    TIM_TimeBaseStructure.TIM_Prescaler = 900-1;
    // 采样时钟分频
    TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
    // 计数方式
    // 初始化定时器TIMx, x[1,8]
    TIM_TimeBaseInit(GENERAL_TIM, &TIM_TimeBaseStructure);
    /* PWM输出模式配置 */
    /* 配置为PWM模式1 */
    /* PWM脉冲宽度 */
    TIM_OCInitStructure.TIM_Pulse = 3000-1;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    /* 使能通道1 */
    TIM_OC1Init(GENERAL_TIM, &TIM_OCInitStructure);
    /*使能通道1重载*/
    TIM_OC1PreloadConfig(GENERAL_TIM, TIM_OCPreload_Enable);
    // 使能定时器
    TIM_Cmd(GENERAL_TIM, ENABLE);
static void TimPwmInputConfig(uint32_t tim_clk, TIM_TypeDef* TIMx, uint16_t tim_channel, TimProperty tim_property)
    TIM_ICInitTypeDef  TIM_ICInitStructure;
    // 开启TIMx_CLK,x[1,8]
//  RCC_APB2PeriphClockCmd(tim_clk, ENABLE);
    // 高级控制定时器时钟源TIMxCLK = HCLK=180MHz
  if (tim_property == High_Tim)
      TIM_TimeBaseStructure.TIM_Period = 0xFFFF-1;
      TIM_TimeBaseStructure.TIM_Prescaler = 1800-1;
  else if (tim_property == Normarl_Tim)
      RCC_APB1PeriphClockCmd(tim_clk, ENABLE);
  else if (tim_property == Normarl_APB2_Tim)
  // 计数方式
    TIM_TimeBaseInit(TIMx, &TIM_TimeBaseStructure);
    /* IC1捕获:上升沿触发 TI1FP1 */
  TIM_ICInitStructure.TIM_Channel = tim_channel;
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  TIM_ICInitStructure.TIM_ICFilter = 0x0;
  TIM_PWMIConfig(TIMx, &TIM_ICInitStructure);
//    /* IC2捕获:下降沿触发 TI1FP2 */
//  TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
//  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling;
//  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_IndirectTI;
//  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
//  TIM_ICInitStructure.TIM_ICFilter = 0x0;
//  TIM_PWMIConfig(TIMx, &TIM_ICInitStructure);
    /* 选择定时器输入触发: TI1FP1 */
  TIM_SelectInputTrigger(TIMx, TIM_TS_TI1FP1);
  /* 选择从模式: 复位模式 */
  TIM_SelectSlaveMode(TIMx, TIM_SlaveMode_Reset);
  TIM_SelectMasterSlaveMode(TIMx,TIM_MasterSlaveMode_Enable);
  /* 使能高级控制定时器 */
  TIM_Cmd(TIMx, ENABLE);
  /* 使能捕获/比较2中断请求 */
  TIM_ITConfig(TIMx, TIM_IT_CC1, ENABLE);
  TIM_ClearITPendingBit(TIMx, TIM_IT_CC1);
void ModelAirPlaneInit(void)
    uint8_t i;
    ModelAirPlaneIrqInit();
    //PWM输出
    TIMx_GPIO_Config(GENERAL_OCPWM_GPIO_CLK, GENERAL_OCPWM_GPIO_PORT, GENERAL_OCPWM_PINSOURCE, GENERAL_OCPWM_AF, GENERAL_OCPWM_PIN);
    TIM_PWMOUTPUT_Config();
    //PWM输入
    for (i = 0; i < ModelAirPlaneKeyNum; i++)
        TIMx_GPIO_Config(PwmInCfg.GPIO_CLK, PwmInCfg.GPIOx, PwmInCfg.GPIO_PinSource, PwmInCfg.GPIO_AF, PwmInCfg.GPIO_Pin);
        TIMx_NVIC_Configuration(PwmInCfg.NVIC_IRQChannel);
        TimPwmInputConfig(PwmInCfg.tim_clk, PwmInCfg.TIMx, PwmInCfg.tim_channel, PwmInCfg.tim_property);
* model_airplane.h
*      Author: mjjol
#ifndef USER_MIDDLE_MODEL_AIRPLANE_MODEL_AIRPLANE_H_
#define USER_MIDDLE_MODEL_AIRPLANE_MODEL_AIRPLANE_H_
#include "stm32f4xx.h"
typedef enum
    Normarl_Tim = 0,
    High_Tim,
    Normarl_APB2_Tim,
} TimProperty;
typedef struct
    uint32_t GPIO_Pin;
    GPIO_TypeDef* GPIOx;
    uint32_t GPIO_CLK;
    uint16_t GPIO_PinSource;
    uint8_t GPIO_AF;
    uint16_t tim_channel;
    TIM_TypeDef* TIMx;
    uint32_t tim_clk;
    uint8_t NVIC_IRQChannel;
    TimProperty tim_property;
} PwmInConfigPro;
extern const PwmInConfigPro PwmInCfg[];
extern void ModelAirPlaneInit(void);
#endif /* USER_MIDDLE_MODEL_AIRPLANE_MODEL_AIRPLANE_H_ */
* model_airplane_def.h
*      Author: mjjol
#ifndef USER_MIDDLE_MODEL_AIRPLANE_MODEL_AIRPLANE_DEF_H_
#define USER_MIDDLE_MODEL_AIRPLANE_MODEL_AIRPLANE_DEF_H_
#define INVALID_IC_VALUE 0xFFFF
/* 通用定时器PWM输出 */
/* PWM输出引脚 */
#define GENERAL_OCPWM_PIN             GPIO_Pin_5
#define GENERAL_OCPWM_GPIO_PORT       GPIOA
#define GENERAL_OCPWM_GPIO_CLK        RCC_AHB1Periph_GPIOA
#define GENERAL_OCPWM_PINSOURCE             GPIO_PinSource5
#define GENERAL_OCPWM_AF                            GPIO_AF_TIM2
/* 通用定时器 */
#define GENERAL_TIM                     TIM2
#define GENERAL_TIM_CLK                 RCC_APB1Periph_TIM2
/************************************IRQ****************************************/
* 此处中断需与
#define ElevatorServo_IRQHandler            TIM8_CC_IRQHandler              //ElevatorServo
#define AileronServo_IRQHandler             TIM3_IRQHandler                 //AileronServo
#define ThrottleServo_IRQHandler            TIM5_IRQHandler                 //ThrottleServo
#define RudderServo_IRQHandler              TIM4_IRQHandler                 //RudderServo
#define GearServo_IRQHandler                TIM1_CC_IRQHandler   //GearServo
typedef enum
    ElevatorServo = 0,
    AileronServo,
    ThrottleServo,
    RudderServo,
    GearServo,
    ModelAirPlaneKeyNum,
} ModelAirPlaneKey;
#endif /* USER_MIDDLE_MODEL_AIRPLANE_MODEL_AIRPLANE_DEF_H_ */
* model_airplane_irq.c
*      Author: mjjol
#include "stm32f4xx_it.h"
PwmICValue PwmIn[ModelAirPlaneKeyNum];
PwmICValue ElevatorServoPwmIn, AileronServoPwmIn;
float DutyCycle = 0, Frequency = 0;
uint8_t IrqLock = 0;
  * @brief  This function handles TIM interrupt request.
  * @param  None
  * @retval None
void  ElevatorServo_IRQHandler (void)
    uint8_t elevatorServo_index = ElevatorServo;
    /* 清除定时器捕获/比较1中断 */
//    TIM_ClearITPendingBit(PwmInCfg[elevatorServo_index].TIMx, TIM_IT_CC1);
    PwmInCfg[elevatorServo_index].TIMx->SR = (uint16_t)~TIM_IT_CC1;
    PwmIn[elevatorServo_index].ic1_value = PwmInCfg[elevatorServo_index].TIMx->CCR1;
    PwmIn[elevatorServo_index].ic2_value = PwmInCfg[elevatorServo_index].TIMx->CCR2;
//    /* 获取输入捕获值 */
//    PwmIn[elevatorServo_index].ic1_value = TIM_GetCapture1(PwmInCfg[elevatorServo_index].TIMx);
//    PwmIn[elevatorServo_index].ic2_value = TIM_GetCapture2(PwmInCfg[elevatorServo_index].TIMx);
    printf("ElevatorServo: IC1Value = %d  IC2Value = %d ",PwmIn[elevatorServo_index].ic1_value,PwmIn[elevatorServo_index].ic2_value);
//    if (PwmIn[elevatorServo_index].ic1_value != 0)
//        /* 占空比计算 */
//        PwmIn[elevatorServo_index].duty_clcye = (float)(PwmIn[elevatorServo_index].ic2_value * 100) / PwmIn[elevatorServo_index].ic1_value;
//        /* 频率计算 */
//        PwmIn[elevatorServo_index].frequency = 180000000/1800/(float)PwmIn[elevatorServo_index].ic1_value;
//        printf("ElevatorServo: 占空比:%0.2f%%   频率:%0.2fHz\r\n",PwmIn[elevatorServo_index].duty_clcye,PwmIn[elevatorServo_index].frequency);
//    else
//        PwmIn[elevatorServo_index].duty_clcye = 0;
//        PwmIn[elevatorServo_index].frequency = 0;
uint16_t tt_c1, tt_c2;
  * @param  None
  * @retval None
void  AileronServo_IRQHandler (void)
    uint8_t aileronServo_index = AileronServo;
    /* 清除定时器捕获/比较1中断 */
//    TIM_ClearITPendingBit(PwmInCfg[aileronServo_index].TIMx, TIM_IT_CC1);
    PwmInCfg[aileronServo_index].TIMx->SR = (uint16_t)~TIM_IT_CC1;
    PwmIn[aileronServo_index].ic1_value = PwmInCfg[aileronServo_index].TIMx->CCR1;
    PwmIn[aileronServo_index].ic2_value = PwmInCfg[aileronServo_index].TIMx->CCR2;
//    /* 获取输入捕获值 */
//    PwmIn[aileronServo_index].ic1_value = TIM_GetCapture1(PwmInCfg[aileronServo_index].TIMx);
//    PwmIn[aileronServo_index].ic2_value = TIM_GetCapture2(PwmInCfg[aileronServo_index].TIMx);
    printf("AileronServo: IC1Value = %d  IC2Value = %d ",PwmIn[aileronServo_index].ic1_value,PwmIn[aileronServo_index].ic2_value);
//    if (PwmIn[aileronServo_index].ic1_value != 0)
//        /* 占空比计算 */
//        PwmIn[aileronServo_index].duty_clcye = (float)(PwmIn[aileronServo_index].ic2_value * 100) / PwmIn[aileronServo_index].ic1_value;
//        /* 频率计算 */
//        PwmIn[aileronServo_index].frequency = 180000000/1800/(float)PwmIn[aileronServo_index].ic1_value;
//        printf("AileronServo: 占空比:%0.2f%%   频率:%0.2fHz\r\n",PwmIn[aileronServo_index].duty_clcye,PwmIn[aileronServo_index].frequency);
//    else
//        PwmIn[aileronServo_index].duty_clcye = 0;
//        PwmIn[aileronServo_index].frequency = 0;
  * @param  None
  * @retval None
void  ThrottleServo_IRQHandler (void)
    uint8_t ThrottleServo_index = ThrottleServo;
    /* 清除定时器捕获/比较1中断 */
//    TIM_ClearITPendingBit(PwmInCfg[ThrottleServo_index].TIMx, TIM_IT_CC1);
    PwmInCfg[ThrottleServo_index].TIMx->SR = (uint16_t)~TIM_IT_CC1;
    PwmIn[ThrottleServo_index].ic1_value = PwmInCfg[ThrottleServo_index].TIMx->CCR1;
    PwmIn[ThrottleServo_index].ic2_value = PwmInCfg[ThrottleServo_index].TIMx->CCR2;
//    /* 获取输入捕获值 */
//    PwmIn[ThrottleServo_index].ic1_value = TIM_GetCapture1(PwmInCfg[ThrottleServo_index].TIMx);
//    PwmIn[ThrottleServo_index].ic2_value = TIM_GetCapture2(PwmInCfg[ThrottleServo_index].TIMx);
    printf("ThrottleServo: IC1Value = %d  IC2Value = %d ",PwmIn[ThrottleServo_index].ic1_value,PwmIn[ThrottleServo_index].ic2_value);
//    if (PwmIn[ThrottleServo_index].ic1_value != 0)
//        /* 占空比计算 */
//        PwmIn[ThrottleServo_index].duty_clcye = (float)(PwmIn[ThrottleServo_index].ic2_value * 100) / PwmIn[ThrottleServo_index].ic1_value;
//        /* 频率计算 */
//        PwmIn[ThrottleServo_index].frequency = 180000000/1800/(float)PwmIn[ThrottleServo_index].ic1_value;
//        printf("ThrottleServo: 占空比:%0.2f%%   频率:%0.2fHz\r\n",PwmIn[ThrottleServo_index].duty_clcye,PwmIn[ThrottleServo_index].frequency);
//    else
//        PwmIn[ThrottleServo_index].duty_clcye = 0;
//        PwmIn[ThrottleServo_index].frequency = 0;
  * @param  None
  * @retval None
void  RudderServo_IRQHandler (void)
    uint8_t RudderServo_index = RudderServo;
    /* 清除定时器捕获/比较1中断 */
//    TIM_ClearITPendingBit(PwmInCfg[RudderServo_index].TIMx, TIM_IT_CC1);
    PwmInCfg[RudderServo_index].TIMx->SR = (uint16_t)~TIM_IT_CC1;
    PwmIn[RudderServo_index].ic1_value = PwmInCfg[RudderServo_index].TIMx->CCR1;
    PwmIn[RudderServo_index].ic2_value = PwmInCfg[RudderServo_index].TIMx->CCR2;
//    /* 获取输入捕获值 */
//    PwmIn[RudderServo_index].ic1_value = TIM_GetCapture1(PwmInCfg[RudderServo_index].TIMx);
//    PwmIn[RudderServo_index].ic2_value = TIM_GetCapture2(PwmInCfg[RudderServo_index].TIMx);
    printf("RudderServo: IC1Value = %d  IC2Value = %d ",PwmIn[RudderServo_index].ic1_value,PwmIn[RudderServo_index].ic2_value);
//    if (PwmIn[RudderServo_index].ic1_value != 0)
//        /* 占空比计算 */
//        PwmIn[RudderServo_index].duty_clcye = (float)(PwmIn[RudderServo_index].ic2_value * 100) / PwmIn[RudderServo_index].ic1_value;
//        /* 频率计算 */
//        PwmIn[RudderServo_index].frequency = 180000000/1800/(float)PwmIn[RudderServo_index].ic1_value;
//        printf("RudderServo: 占空比:%0.2f%%   频率:%0.2fHz\r\n",PwmIn[RudderServo_index].duty_clcye,PwmIn[RudderServo_index].frequency);
//    else
//        PwmIn[RudderServo_index].duty_clcye = 0;
//        PwmIn[RudderServo_index].frequency = 0;
  * @param  None
  * @retval None
void  GearServo_IRQHandler (void)
    uint8_t GearServo_index = GearServo;
    /* 清除定时器捕获/比较1中断 */
//    TIM_ClearITPendingBit(PwmInCfg[GearServo_index].TIMx, TIM_IT_CC1);
    PwmInCfg[GearServo_index].TIMx->SR = (uint16_t)~TIM_IT_CC1;
    PwmIn[GearServo_index].ic1_value = PwmInCfg[GearServo_index].TIMx->CCR1;
    PwmIn[GearServo_index].ic2_value = PwmInCfg[GearServo_index].TIMx->CCR2;
    /* 获取输入捕获值 */
//    PwmIn[GearServo_index].ic1_value = TIM_GetCapture1(PwmInCfg[GearServo_index].TIMx);
//    PwmIn[GearServo_index].ic2_value = TIM_GetCapture2(PwmInCfg[GearServo_index].TIMx);
    printf("GearServo: IC1Value = %d  IC2Value = %d ",PwmIn[GearServo_index].ic1_value,PwmIn[GearServo_index].ic2_value);
//    if (PwmIn[GearServo_index].ic1_value != 0)
//        /* 占空比计算 */
//        PwmIn[GearServo_index].duty_clcye = (float)(PwmIn[GearServo_index].ic2_value * 100) / PwmIn[GearServo_index].ic1_value;
//        /* 频率计算 */
//        PwmIn[GearServo_index].frequency = 180000000/1800/(float)PwmIn[GearServo_index].ic1_value;
//        printf("GearServo: 占空比:%0.2f%%   频率:%0.2fHz\r\n",PwmIn[GearServo_index].duty_clcye,PwmIn[GearServo_index].frequency);
//    else
//        PwmIn[GearServo_index].duty_clcye = 0;
//        PwmIn[GearServo_index].frequency = 0;
void ModelAirPlaneIrqInit(void)
    uint8_t i;
        PwmIn.ic1_value = INVALID_IC_VALUE;
        PwmIn.ic2_value = INVALID_IC_VALUE;
GMT+8, 2020-8-13 00:07 , Processed in 0.145038 second(s), 27 queries , Gzip On.
