查看: 142|回复: 4
串口发送汉字问题
发表于 2020-9-13 15:10:59 | 显示全部楼层 |阅读模式
用火哥例程发送汉字完全没问题
但是我自己编的发送汉字就出现的乱码如图
#include "TEST_UART.h"
#include "stm32f10x.h"
static void NVIC_config()
        NVIC_InitTypeDef NVIC_struct;
        NVIC_struct.NVIC_IRQChannel = USART1_IRQn;
        NVIC_struct.NVIC_IRQChannelCmd = ENABLE;
        NVIC_struct.NVIC_IRQChannelPreemptionPriority = 1;
        NVIC_struct.NVIC_IRQChannelSubPriority= 1;
        NVIC_Init(&NVIC_struct);
void UARTconfig()
        USART_InitTypeDef USART_struct;
        GPIO_InitTypeDef GPIO_struct;
        //开启时钟 GPIO  USART AFIO
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
        //初始化GPIO配置        TX RX
        //TX
        GPIO_struct.GPIO_Pin = GPIO_Pin_9;
        GPIO_struct.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_struct.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOA,&GPIO_struct);
        //RX
        GPIO_struct.GPIO_Pin = GPIO_Pin_10;
        GPIO_struct.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        //初始化USART
        USART_struct.USART_BaudRate = 115200;
        USART_struct.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_struct.USART_Mode = USART_Mode_Tx|USART_Mode_Rx;
        USART_struct.USART_Parity = USART_Parity_No;
        USART_struct.USART_StopBits = USART_StopBits_1;
        USART_struct.USART_WordLength = USART_WordLength_8b;
        USART_Init(USART1,&USART_struct);
        //初始化NVIC
        NVIC_config();
//使能串口接收中断
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
        //使能串口
        USART_Cmd(USART1,ENABLE);
void SendByte(USART_TypeDef* USARTx,uint8_t data)
        USART_SendData(USARTx,data);
        while(USART_GetFlagStatus(USARTx,USART_FLAG_TXE)==RESET);
void SendString(USART_TypeDef* USARTx,char *string)
        unsigned int k=0;
        do
        SendByte(USARTx,*(string+k));
                k++;
        }while(*(string+k)!='\0');
        while(USART_GetFlagStatus(USARTx,USART_FLAG_TC)==RESET)
void SendHalfWord(USART_TypeDef* USARTx,uint16_t data)
        uint8_t Htemp,Ltemp;
        Htemp=data>>8;
        Ltemp=(data & 0x00ff);
        SendByte(USARTx,Htemp);
        while (USART_GetFlagStatus(USARTx, USART_FLAG_TXE) == RESET);
        SendByte(USARTx,Ltemp);
///重定向c库函数printf到串口,重定向后可使用printf函数
int fputc(int ch, FILE *f)
                /* 发送一个字节数据到串口 */
                USART_SendData(USART1, (uint8_t) ch);
                /* 等待发送完毕 */
                while (USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
                return (ch);
///重定向c库函数scanf到串口,重写向后可使用scanf、getchar等函数
int fgetc(FILE *f)
                /* 等待串口输入数据 */
                while (USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET);
                return (int)USART_ReceiveData(USART1);
//void SendWord(USART_TypeDef* USARTx,uint32_t data)
发表于 2020-9-14 08:51:35 | 显示全部楼层
将keil的编码方式更换为GB2312或者ANSI试一下
 楼主| 发表于 2020-9-14 10:48:28 | 显示全部楼层
谢谢老哥解答!  但是还是没有解决    本来用的就是GB2312 换成ANSI还是不行
发表于 2020-9-14 17:54:29 | 显示全部楼层
UTF8- -
 楼主| 发表于 5 天前 | 显示全部楼层
在微软商店里重新下载了一个调试助手  显示正常了
可能就是编码方式的问题吧     但是使用火哥的显示例程就正常       如果有人知道详细原因    恳请指教!
GMT+8, 2020-9-22 13:40 , Processed in 0.225241 second(s), 29 queries , Gzip On.
