查看: 20540|回复: 1
用F1驱动LCD5110显示不出来,这是为什么,51 上是可以的
发表于 2017-7-9 16:24:55 | 显示全部楼层 |阅读模式
#include "bsp_lcd.h"
unsigned char shuzi[]={
        0x00,0xFC,0x02,0x02,0x02,0xFC,0x00,0x00,0x01,0x01,0x01,0x00, // -0-
        0x00,0x00,0x02,0xFE,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01, // -1-
        0x00,0x84,0x42,0x22,0x12,0x8C,0x00,0x01,0x01,0x01,0x01,0x01, // -2-
        0x00,0x84,0x02,0x12,0x12,0xEC,0x00,0x00,0x01,0x01,0x01,0x00, // -3-
        0x00,0x60,0x50,0x4C,0x42,0xFE,0x00,0x00,0x00,0x00,0x01,0x01, // -4-
        0x00,0x80,0x1E,0x12,0x12,0xE2,0x00,0x00,0x01,0x01,0x01,0x00, // -5-
        0x00,0xF8,0x14,0x12,0x12,0xE2,0x00,0x00,0x01,0x01,0x01,0x00, // -6-
        0x00,0x06,0x02,0x82,0x72,0x0E,0x00,0x00,0x00,0x01,0x00,0x00, // -7-
        0x00,0xEC,0x12,0x12,0x12,0xEC,0x00,0x00,0x01,0x01,0x01,0x00, // -8-
        0x00,0x1C,0x22,0x22,0xA2,0x7C,0x00,0x01,0x01,0x01,0x00,0x00, // -9-
unsigned char hanzi[]={
      0x90,0x8C,0x84,0xAC,0xD4,0x85,0xF6,0x84,0x84,0x84,0xD4,0x8C,
      0x00,0x08,0x08,0x08,0x04,0x02,0x01,0x02,0x02,0x04,0x08,0x00,
          0xFC,0x24,0x24,0x24,0xFC,0x08,0x28,0xC8,0x08,0xFF,0x08,0x08,
      0x03,0x01,0x01,0x01,0x03,0x00,0x00,0x04,0x08,0x0F,0x00,0x00,
           0x08,0x08,0x88,0x68,0x18,0x00,0xFF,0x20,0xD0,0x08,0x04,0x00,
      0x04,0x02,0x01,0x00,0x04,0x08,0x07,0x00,0x00,0x01,0x06,0x02,
           0x20,0x10,0xFC,0x03,0x04,0x34,0xC5,0x06,0x04,0xF6,0x04,0x04,
      0x00,0x00,0x0F,0x00,0x08,0x08,0x0B,0x08,0x0F,0x08,0x08,0x08
void LCD_GPIO_Init(void)
                        GPIO_InitTypeDef GPIO_InitStruct;//定义GPIO口的输出结构体
                        RCC_APB2PeriphClockCmd(GPIO_RCC,ENABLE);
                        GPIO_InitStruct.GPIO_Pin=GPIO_Pin_All;//设置要控制的GPIO口
                        GPIO_InitStruct.GPIO_Speed=GPIO_Speed_2MHz;          //设置输出速度
            GPIO_InitStruct.GPIO_Mode=GPIO_Mode_Out_PP;//设置成推挽输出
            GPIO_Init(LCD_GPIO_PORT,&GPIO_InitStruct);            //初始化GPIO口
      LCD_init();
void delay_1ms(void)
   unsigned int i;
  for(i=0;i<12000;i++)
        void LCD_write_byte(unsigned char dat, unsigned char command)
    unsigned char i;
    LCD_CE_L;
    if (command == 0)
     LCD_DC_L;
                        LCD_DC_H;
                for(i=0;i<8;i++)
                        if(dat&0x80)
                                LCD_Din_H;
                                LCD_Din_L;
                                dat = dat << 1;
                        LCD_CLK_L;
                        LCD_CLK_H;
      LCD_DC_H;
      LCD_CE_H;
                  LCD_Din_H;
                void LCD_init(void)
    LCD_RST_L;
    delay_1ms();
    LCD_RST_H;
          LCD_CE_H;
                delay_1ms();
          LCD_CE_L;
    LCD_write_byte(0x21, 0);
    LCD_write_byte(0xc6, 0);
    LCD_write_byte(0x06, 0);
    LCD_write_byte(0x13, 0);
    LCD_write_byte(0x20, 0);
    LCD_write_byte(0x0c, 0);
          LCD5110_SetContrast(68);
void LCD_set_XY(unsigned char X, unsigned char Y)
    LCD_write_byte(0x40 | Y, 0);
    LCD_write_byte(0x80 | X, 0);
void LCD_clear(void)
           unsigned char t,k;
                 LCD_set_XY(0,0);
                 for(t=0;t<6;t++)
                                for(k=0;k<84;k++)
                                        LCD_write_byte(0x00,1);
void LCD_write_char(unsigned char row,unsigned char page,unsigned char c)
     unsigned char i;
                 LCD_set_XY(row*6,page);
           for(i=0;i<6;i++)
                         LCD_write_byte(shuzi[c*12+i],1);
                LCD_set_XY(row*6,page+1);
                for(i=6;i<12;i++)
void LCD_write_chinese_string(unsigned char row,unsigned char page,unsigned char c)
     unsigned char i;
   LCD_set_XY(row*12,page);
   for(i=0;i<12;i++)
      LCD_write_byte(hanzi[c*24+i],1);
   LCD_set_XY(row*12,page+1);
   for(i=12;i<24;i++)
void LCD5110_SetContrast(uint8_t contrast)
         LCD_write_byte(0x21,0);
         LCD_write_byte(0x80|contrast,0);
         LCD_write_byte(0x20,0);
void display11(void)
        LCD_write_chinese_string(0,2,0);
        LCD_write_chinese_string(1,2,1);
        LCD_write_chinese_string(2,2,2);
        LCD_write_chinese_string(3,2,3);
 楼主| 发表于 2017-7-9 16:26:22 | 显示全部楼层
原理看着技术手册是知道的,但是就是显示不了
GMT+8, 2026-11-24 14:00 , Processed in 0.039160 second(s), 24 queries , Gzip On.
