查看: 22084|回复: 4
uCOS-III源码精读以后找到的bug,大家一起来讨论下
发表于 2017-7-27 20:19:53 | 显示全部楼层 |阅读模式
1、flag.c中:
void  OS_FlagTaskRdy (OS_TCB    *p_tcb,
                       OS_FLAGS   flags_rdy,
                       CPU_TS     ts)
   p_tcb->FlagsRdy   = flags_rdy;
p_tcb->PendStatus= OS_STATUS_PEND_OK;
p_tcb->PendOn     = OS_TASK_PEND_ON_NOTHING;
   p_tcb->TS         = ts;
   switch (p_tcb->TaskState) {
       case OS_TASK_STATE_RDY:
       case OS_TASK_STATE_DLY:
       case OS_TASK_STATE_DLY_SUSPENDED:
       case OS_TASK_STATE_SUSPENDED:
            break;
       case OS_TASK_STATE_PEND:
       case OS_TASK_STATE_PEND_TIMEOUT:
            OS_TaskRdy(p_tcb);
            p_tcb->TaskState = OS_TASK_STATE_RDY;
            break;
       case OS_TASK_STATE_PEND_SUSPENDED:
       case OS_TASK_STATE_PEND_TIMEOUT_SUSPENDED:
             p_tcb->TaskState =OS_TASK_STATE_SUSPENDED;    //这里应该有                   //OS_TickListRemove(p_tcb);
            break;
       default:
            break;
   OS_PendListRemove(p_tcb);
2、OSFlagPend()中,参数检查程序段:
#if OS_CFG_ARG_CHK_EN > 0u
   if (p_grp == (OS_FLAG_GRP *)0) {
      *p_err = OS_ERR_OBJ_PTR_NULL;
       return ((OS_FLAGS)0);
   switch (opt) {
       case OS_OPT_PEND_FLAG_CLR_ALL:
       case OS_OPT_PEND_FLAG_CLR_ANY:
       case OS_OPT_PEND_FLAG_SET_ALL:
       case OS_OPT_PEND_FLAG_SET_ANY:
       case OS_OPT_PEND_FLAG_CLR_ALL | OS_OPT_PEND_FLAG_CONSUME:
       case OS_OPT_PEND_FLAG_CLR_ANY | OS_OPT_PEND_FLAG_CONSUME:
       case OS_OPT_PEND_FLAG_SET_ALL | OS_OPT_PEND_FLAG_CONSUME:
       case OS_OPT_PEND_FLAG_SET_ANY | OS_OPT_PEND_FLAG_CONSUME:
       case OS_OPT_PEND_FLAG_CLR_ALL | OS_OPT_PEND_NON_BLOCKING:
       case OS_OPT_PEND_FLAG_CLR_ANY | OS_OPT_PEND_NON_BLOCKING:
       case OS_OPT_PEND_FLAG_SET_ALL | OS_OPT_PEND_NON_BLOCKING:
       case OS_OPT_PEND_FLAG_SET_ANY | OS_OPT_PEND_NON_BLOCKING:
       case OS_OPT_PEND_FLAG_CLR_ALL | OS_OPT_PEND_FLAG_CONSUME |OS_OPT_PEND_NON_BLOCKING:
       case OS_OPT_PEND_FLAG_CLR_ANY | OS_OPT_PEND_FLAG_CONSUME |OS_OPT_PEND_NON_BLOCKING:
       case OS_OPT_PEND_FLAG_SET_ALL | OS_OPT_PEND_FLAG_CONSUME |OS_OPT_PEND_NON_BLOCKING:
       case OS_OPT_PEND_FLAG_SET_ANY | OS_OPT_PEND_FLAG_CONSUME |OS_OPT_PEND_NON_BLOCKING:
            break;
       default:
           *p_err = OS_ERR_OPT_INVALID;
            return ((OS_OBJ_QTY)0);
#endif
当系统配置未使能宏:OS_CFG_FLAG_MODE_CLR_EN时,opt里出现与CLR相关的宏,这个参数检查应该报错才对。实际上,当出现未使能宏OS_CFG_FLAG_MODE_CLR_EN,却在opt中使能了CLR相关选项,在这段参数检查代码中没有报错,但是在OSFlagPend()后续的处理中也会报错,给err值赋值OS_ERR_OPT_INVALID。
3、所有内核对象的PendAbort()函数中,以下代码段:
while (p_pend_list->NbrEntries >(OS_OBJ_QTY)0u) {
       p_tcb = p_pend_list->HeadPtr->TCBPtr;
       OS_PendAbort((OS_PEND_OBJ *)((void *)p_grp),
                     p_tcb,
                     ts);
       nbr_tasks++;
       if (opt != OS_OPT_PEND_ABORT_ALL) {
break;   // //应该算上OS_OPT_PEND_ABORT_ALL| OS_OPT_POST_NO_SCHED
4、OS_TaskInitTCB( )在OSTaskCreate()时会被调用,用来初始化tcb中的各字段,里面有一段:
#if (OS_CFG_PEND_MULTI_EN > 0u)
   p_tcb->PendDataTblPtr     =(OS_PEND_DATA  *)0;
   p_tcb->PendDataTblEntries = (OS_OBJ_QTY     )0u;
#endif
其实这里不需要条件编译,无论如何PendDataTblPtr和PendDataTblEntries都应该是存在于tcb中的,都应该在初始化时被清零。
5、OS_TickListInsert()中,若opt==OS_OPT_TIME_PERIODIC时,它需要用用到保存在TCB结构体中与tick操作相关的一个变量->TickCtrPerv,这个变量记录的是上一次调用延时函数OSTimeDly时算出来的->TickCtrMatch,但是如果是第一次进入OSTimeDly()使用OS_OPT_TIME_PERIODIC选项时,就会出问题,这时TCB里记录的TickCtrPrev等于0.
6、 以下应该不是bug,我对此抱有疑问。所有的Pend函数中,比如OSSemPend()、OSTaskQPend()函数,在从阻塞态恢复调度后:
OSSched();
   CPU_CRITICAL_ENTER();
   switch (OSTCBCurPtr->PendStatus) {
       case OS_STATUS_PEND_OK:
            p_void      =OSTCBCurPtr->MsgPtr;
           *p_msg_size  =OSTCBCurPtr->MsgSize;
            if (p_ts != (CPU_TS *)0) {
                *p_ts  = OSTCBCurPtr->TS;
           *p_err = OS_ERR_NONE;
            break;
       case OS_STATUS_PEND_ABORT:
            p_void     = (void      *)0;
           *p_msg_size = (OS_MSG_SIZE)0;
                *p_ts   = (CPU_TS )0;  //这里我觉得应该是:*p_ts  = OSTCBCurPtr->TS;
           *p_err      =  OS_ERR_PEND_ABORT;
            break;
       case OS_STATUS_PEND_TIMEOUT:
       default:
            p_void     = (void      *)0;
           *p_err      =  OS_ERR_TIMEOUT;
            break;
版本号  OS_VERSION == 30300
发表于 2017-7-28 09:25:29 | 显示全部楼层
楼主有心了,好好研究
发表于 2017-7-28 09:49:54 | 显示全部楼层
必成大器
 楼主| 发表于 2017-7-28 16:24:12 | 显示全部楼层
同感同感~
发表于 2017-7-29 12:01:46 | 显示全部楼层
没研究过uCOS,一直用的是FreeRTOS
GMT+8, 2026-10-8 23:46 , Processed in 0.044619 second(s), 24 queries , Gzip On.
