查看: 20899|回复: 3
求助:429开发板双层显示闪烁的问题
发表于 2018-3-20 09:07:45 | 显示全部楼层 |阅读模式
实测《21-LTDC—液晶显示汉字(显示任意大小)》的例程,发现双层显示使用的都是ARGB1555格式,如果都换成RGB565,或者一层是ARGB15555另外一层使用RGB565,则屏幕都会闪烁。
求解,谢谢!
void LCD_LayerInit(void)
LTDC_Layer_InitTypeDef LTDC_Layer_InitStruct;
  /* 层窗口配置 */
  /* 配置本层的窗口边界,注意这些参数是包含HBP HSW VBP VSW的 */
        //一行的第一个起始像素,该成员值应用为 (LTDC_InitStruct.LTDC_AccumulatedHBP+1)的值
        LTDC_Layer_InitStruct.LTDC_HorizontalStart = HBP + HSW;
        //一行的最后一个像素,该成员值应用为 (LTDC_InitStruct.LTDC_AccumulatedActiveW)的值
        LTDC_Layer_InitStruct.LTDC_HorizontalStop = HSW+HBP+LCD_PIXEL_WIDTH-1;
        //一列的第一个起始像素,该成员值应用为 (LTDC_InitStruct.LTDC_AccumulatedVBP+1)的值
        LTDC_Layer_InitStruct.LTDC_VerticalStart =  VBP + VSW;
        //一列的最后一个像素,该成员值应用为 (LTDC_InitStruct.LTDC_AccumulatedActiveH)的值
        LTDC_Layer_InitStruct.LTDC_VerticalStop = VSW+VBP+LCD_PIXEL_HEIGHT-1;
/* Pixel Format configuration*/
LTDC_Layer_InitStruct.LTDC_PixelFormat = LTDC_Pixelformat_RGB565;
/* Alpha constant (255 totally opaque) */
LTDC_Layer_InitStruct.LTDC_ConstantAlpha = 255;
/* Default Color configuration (configure A,R,G,B component values) */
LTDC_Layer_InitStruct.LTDC_DefaultColorBlue = 0;
LTDC_Layer_InitStruct.LTDC_DefaultColorGreen = 0;
LTDC_Layer_InitStruct.LTDC_DefaultColorRed = 0;
LTDC_Layer_InitStruct.LTDC_DefaultColorAlpha = 0;
/* Configure blending factors */
LTDC_Layer_InitStruct.LTDC_BlendingFactor_1 = LTDC_BlendingFactor1_CA;
LTDC_Layer_InitStruct.LTDC_BlendingFactor_2 = LTDC_BlendingFactor2_CA;
/* the length of one line of pixels in bytes + 3 then :
Line Lenth = Active high width x number of bytes per pixel + 3
Active high width         = LCD_PIXEL_WIDTH
number of bytes per pixel = 2    (pixel_format : RGB565)
LTDC_Layer_InitStruct.LTDC_CFBLineLength = ((LCD_PIXEL_WIDTH * 2) + 3);
/* the pitch is the increment from the start of one line of pixels to the
start of the next line in bytes, then :
Pitch = Active high width x number of bytes per pixel */
LTDC_Layer_InitStruct.LTDC_CFBPitch = (LCD_PIXEL_WIDTH * 2);
/* Configure the number of lines */
LTDC_Layer_InitStruct.LTDC_CFBLineNumber = LCD_PIXEL_HEIGHT;
/* Start Address configuration : the LCD Frame buffer is defined on SDRAM */
LTDC_Layer_InitStruct.LTDC_CFBStartAdress = LCD_FRAME_BUFFER;
/* Initialize LTDC layer 1 */
LTDC_LayerInit(LTDC_Layer1, <DC_Layer_InitStruct);
  /* Configure Layer2 */
LTDC_Layer_InitStruct.LTDC_PixelFormat = LTDC_Pixelformat_ARGB1555;
  /* Start Address configuration : the LCD Frame buffer is defined on SDRAM w/ Offset */
LTDC_Layer_InitStruct.LTDC_CFBStartAdress = LCD_FRAME_BUFFER + BUFFER_OFFSET;
LTDC_Layer_InitStruct.LTDC_BlendingFactor_1 = LTDC_BlendingFactor1_PAxCA;
LTDC_Layer_InitStruct.LTDC_BlendingFactor_2 = LTDC_BlendingFactor2_PAxCA;
  /* Initialize LTDC layer 2 */
LTDC_LayerInit(LTDC_Layer2, <DC_Layer_InitStruct);
  /* LTDC configuration reload */
LTDC_ReloadConfig(LTDC_IMReload);
  /* Enable foreground & background Layers */
LTDC_LayerCmd(LTDC_Layer1, ENABLE);
LTDC_LayerCmd(LTDC_Layer2, ENABLE);
  /* Set default font */
LCD_SetFont(&LCD_DEFAULT_FONT);
  /* dithering activation */
LTDC_DitherCmd(ENABLE);
发表于 2018-3-20 10:48:17 | 显示全部楼层
感觉429性能不够,特殊点的都会闪烁
发表于 2018-3-20 13:17:42 | 显示全部楼层
RGB1555的格式应该是合适的。可以随行控制背景层的透明或不透明。
系统一般不会闪烁。偶然会稍有闪烁。估计改变液晶的工作频率会改善。
 楼主| 发表于 2018-3-21 07:32:22 | 显示全部楼层
系统一般不会闪烁。偶然会稍有闪烁。估 ...
我需要背景层是565,前景层是1555,但是设置后闪烁比较明显。
GMT+8, 2026-11-25 02:17 , Processed in 0.055402 second(s), 23 queries , Gzip On.
