查看: 15286|回复: 4
关于4X4矩阵键盘的问题,main函数实在不会写,基本都是只给键盘的算法。
发表于 2018-4-14 13:45:52 | 显示全部楼层 |阅读模式
感觉找遍了全网,也没找到main函数控制led或者是relay继电器的语句,c语言实在是没有精通,各位大大可以帮忙看下这个是什么情况么,就是没法点亮我的板载led,我用的是f429.下面是我的程序。第一段main.c
  1. #include "stm32f4xx.h" //寄存器外设地址映射
  2. #include "bsp_keyboard.h"
  3. #include "bsp_led.h"
  4. int main(void)
  5. {
  6.   int KeyNumber;
  7.         LED_GPIO_Config();
  8.         KeyBoard_GPIO_Config();
  9.         Key_Scan();
  10.         while(1)
  11.         {
  12.                 KeyNumber = Key_Scan();
  13.                 switch(KeyNumber)
  14.                 {
  15.                         case 1 :
  16.                                 LED_G_ON;     break;
 楼主| 发表于 2018-4-14 13:47:28 | 显示全部楼层
第二段是我写的4X4键盘的bsp_keyboard.c
  1. #include "bsp_keyboard.h"
  2. #include "stm32f4xx_gpio.h"
  3. #include "stm32f4xx_rcc.h"
  4. void Delay_ms(int xms)
  5. {
  6.   uint32_t i,j;
  7.         for(i=xms;i>0;i--)
  8.           for(j=72000;j>0;j--);
  9. }
  10. void KeyBoard_GPIO_Config(void)
  11. {
  12.         GPIO_InitTypeDef  GPIO_InitStructure;
  13.         RCC_AHB1PeriphClockCmd(C1_GPIO_CLK|
  14.                                      R1_GPIO_CLK,ENABLE);
  15.
  16.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  17.         GPIO_InitStructure.GPIO_OType =GPIO_OType_PP;
  18.         GPIO_InitStructure.GPIO_Speed= GPIO_Speed_50MHz;
  19.               GPIO_InitStructure.GPIO_Pin  = C1_PIN |C2_PIN |C3_PIN |C4_PIN ;
  20.         GPIO_Init(GPIOC,&GPIO_InitStructure);
  21.
  22.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  23.               GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  24.         GPIO_InitStructure.GPIO_Pin  = R1_PIN|R2_PIN|R3_PIN|R4_PIN;//DD
  25.         GPIO_Init(GPIOA,&GPIO_InitStructure);
  26. }
  27. int Key_Scan(void)
  28. {
  29.         uint8_t KeyVal;
  30.         GPIO_Write(GPIOC,((GPIOC->ODR & 0xf0ff) | 0x0f00));
  31.         if((GPIOA->IDR & 0xf000)==0x0000)
  32.                 return -1;
  33.         else
  34.         {
  35.             Delay_ms(5);
  36.             if((GPIOA->IDR & 0xf000)==0x0000)
  37.             return -1;
  38.         }
  39.         GPIO_Write(GPIOC,((GPIOC->ODR & 0xf0ff) | 0x0100));
  40.                 switch(GPIOA->IDR & 0xf000)
  41.                         {
  42.                                 case 0x1000: KeyVal=15; break;
  43.                                 case 0x2000: KeyVal=11;        break;
  44.                                 case 0x4000: KeyVal=7;        break;
  45.                                 case 0x8000: KeyVal=3;        break;
  46.                         }
  47.         GPIO_Write(GPIOC,((GPIOC->ODR & 0xf0ff) | 0x0200));
  48.                 switch(GPIOA->IDR & 0xf000)
  49.                 {
  50.                         case 0x1000: KeyVal=14;        break;
  51.                         case 0x2000: KeyVal=10;        break;
  52.                         case 0x4000: KeyVal=6;        break;
  53.                         case 0x8000: KeyVal=2;        break;
  54.                 }
  55.         GPIO_Write(GPIOC,((GPIOC->ODR & 0xf0ff) | 0x0400));
  56.                 switch(GPIOA->IDR & 0xf000)
  57.                 {
  58.                         case 0x1000: KeyVal=13;        break;
  59.                         case 0x2000: KeyVal=9;        break;
  60.                         case 0x4000: KeyVal=5;        break;
  61.                         case 0x8000: KeyVal=1;        break;
  62.                 }
  63.         GPIO_Write(GPIOC,((GPIOC->ODR & 0xf0ff) | 0x0800));
  64.                 switch(GPIOA->IDR & 0xf000)
  65.                 {
  66.                         case 0x1000: KeyVal=12;        break;
  67.                         case 0x2000: KeyVal=8;        break;
  68.                         case 0x4000: KeyVal=4;        break;
  69.                         case 0x8000: KeyVal=0;        break;
  70.                 }
  71.
  72.         return KeyVal;
  73. }
 楼主| 发表于 2018-4-14 13:48:22 | 显示全部楼层
第三段是.h文件
  1. #ifndef __BSP_KEYBOARD_H
  2. #define __BSP_KEYBOARD_H
  3. #include "stm32f4xx.h"
  4. #include "stm32f4xx_gpio.h"
  5. #include "stm32f4xx_rcc.h"
  6. //引脚定义
  7. /*******************************************************/
  8. #define C1_PIN                  GPIO_Pin_8
  9. #define C1_GPIO_PORT            GPIOC
  10. #define C1_GPIO_CLK             RCC_AHB1Periph_GPIOC
  11. #define C2_PIN                  GPIO_Pin_9
  12. #define C2_GPIO_PORT            GPIOC
  13. #define C2_GPIO_CLK             RCC_AHB1Periph_GPIOC
  14. #define C3_PIN                  GPIO_Pin_10
  15. #define C3_GPIO_PORT            GPIOC
  16. #define C3_GPIO_CLK             RCC_AHB1Periph_GPIOC
  17. #define C4_PIN                  GPIO_Pin_11
  18. #define C4_GPIO_PORT            GPIOC
  19. #define C4_GPIO_CLK             RCC_AHB1Periph_GPIOC
  20. #define R1_PIN                  GPIO_Pin_1
  21. #define R1_GPIO_PORT            GPI0A
  22. #define R1_GPIO_CLK             RCC_AHB1Periph_GPIOA
  23. #define R2_PIN                  GPIO_Pin_2
  24. #define R2_GPIO_PORT            GPIOA
  25. #define R2_GPIO_CLK             RCC_AHB1Periph_GPIOA
  26. #define R3_PIN                  GPIO_Pin_3
  27. #define R3_GPIO_PORT            GPIOA
  28. #define R3_GPIO_CLK             RCC_AHB1Periph_GPIOA
  29. #define R4_PIN                  GPIO_Pin_4
  30. #define R4_GPIO_PORT            GPIOA
  31. #define R4_GPIO_CLK             RCC_AHB1Periph_GPIOA
  32. /*******************************************************/
  33. int Key_Scan(void);
  34. void KeyBoard_GPIO_Config(void);
  35. #endif /*__BSP_KEYBOARD_H */
 楼主| 发表于 2018-4-14 13:51:05 | 显示全部楼层
  1. //主函数中的
  2. LED_GPIO_Config(); //这句肯定是可以实现的所以就不展示代码了。
所以不可能是我灯有问题,通过万用表检测也能测试出我的矩阵键盘不是硬件问题,所以只能是我的代码有着严重的缺陷,希望大佬可以帮帮忙。。
发表于 2018-4-17 14:29:06 | 显示全部楼层
初始化键盘输入
初始化键盘输出
读取键盘输入
对应led输出(最好是用翻转的)
凉凉
GMT+8, 2026-11-22 09:39 , Processed in 0.044946 second(s), 24 queries , Gzip On.
