查看: 22366|回复: 3
高级定时器TIM1的三个通道延时输出问题
发表于 2018-4-18 12:21:15 | 显示全部楼层 |阅读模式
static void ADVANCE_TIM_GPIO_Config(void)
        RCC_APB2PeriphClockCmd(ADVANCE_TIM_CH1_GPIO_CLK|ADVANCE_TIM_CH2_GPIO_CLK|ADVANCE_TIM_CH3_GPIO_CLK, ENABLE);
  GPIO_InitStructure.GPIO_Pin =  ADVANCE_TIM_CH1_PIN;
  GPIO_Init(ADVANCE_TIM_CH1_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin =  ADVANCE_TIM_CH2_PIN;
        GPIO_Init(ADVANCE_TIM_CH2_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin =  ADVANCE_TIM_CH3_PIN;
        GPIO_Init(ADVANCE_TIM_CH3_PORT, &GPIO_InitStructure);
        RCC_APB2PeriphClockCmd(ADVANCE_TIM_CH1N_GPIO_CLK|ADVANCE_TIM_CH2N_GPIO_CLK|ADVANCE_TIM_CH3N_GPIO_CLK, ENABLE);
  GPIO_InitStructure.GPIO_Pin =  ADVANCE_TIM_CH1N_PIN;
  GPIO_Init(ADVANCE_TIM_CH1N_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin =  ADVANCE_TIM_CH2N_PIN;
        GPIO_Init(ADVANCE_TIM_CH2N_PORT, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin =  ADVANCE_TIM_CH3N_PIN;
        GPIO_Init(ADVANCE_TIM_CH3N_PORT, &GPIO_InitStructure);
        RCC_APB2PeriphClockCmd(ADVANCE_TIM_BKIN_GPIO_CLK, ENABLE);
  GPIO_InitStructure.GPIO_Pin =  ADVANCE_TIM_BKIN_PIN;
  GPIO_Init(ADVANCE_TIM_BKIN_PORT, &GPIO_InitStructure);
        GPIO_ResetBits(ADVANCE_TIM_BKIN_PORT,ADVANCE_TIM_BKIN_PIN);
static void ADVANCE_TIM_Mode_Config(void)
        ADVANCE_TIM_APBxClock_FUN(ADVANCE_TIM_CLK,ENABLE);
        TIM_TimeBaseStructure.TIM_Period=ADVANCE_TIM_PERIOD;
        TIM_TimeBaseStructure.TIM_Prescaler= ADVANCE_TIM_PSC;
        TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBaseStructure.TIM_RepetitionCounter=0;
        TIM_TimeBaseInit(ADVANCE_TIM, &TIM_TimeBaseStructure);
        TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
        TIM_OCInitStructure.TIM_Pulse = ADVANCE_TIM_PULSE;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
        TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
        TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;
        TIM_OC1Init(ADVANCE_TIM, &TIM_OCInitStructure);
        TIM_OC1PreloadConfig(ADVANCE_TIM, TIM_OCPreload_Enable);
       TIM_OC2Init(ADVANCE_TIM, &TIM_OCInitStructure);
        TIM_OC3Init(ADVANCE_TIM, &TIM_OCInitStructure);
        TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
  TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
  TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
  TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;
  TIM_BDTRInitStructure.TIM_DeadTime = 22;                            //305ns
  TIM_BDTRInitStructure.TIM_Break = TIM_Break_Enable;
  TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
  TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
  TIM_BDTRConfig(ADVANCE_TIM, &TIM_BDTRInitStructure);
        TIM_Cmd(ADVANCE_TIM, ENABLE);
        TIM_CtrlPWMOutputs(ADVANCE_TIM, ENABLE);
void ADVANCE_TIM_Config(void)
        ADVANCE_TIM_GPIO_Config();
        ADVANCE_TIM_Mode_Config();
       SysTick_Delay_Us( (ADVANCE_TIM_PERIOD+1)/3);
        TIM_OC2PreloadConfig(ADVANCE_TIM, TIM_OCPreload_Enable);
        TIM_OC3PreloadConfig(ADVANCE_TIM, TIM_OCPreload_Enable);
以上代码是通过例程修改而来,现在想把三个通道分别延时三分之一同期再输出,通过延时三分之一周期再使能通道2,再延时三分之一周期使能通道3,不知道这方法行不行。我没示波器也不知道有没有延时输出。
发表于 2018-4-18 14:05:19 | 显示全部楼层
工程分享出来。有示波器的可以实测一下
 楼主| 发表于 2018-4-18 14:41:44 | 显示全部楼层
好的,我在假设上面方法可行的前提下写了电机运行函数,有两个参数,一个参数控制方向,一个参数控制频率。工程怎么分享,附件只能上传一个文件,怎么上传文件夹。
 楼主| 发表于 2018-4-18 14:49:26 | 显示全部楼层
以下是bsp_AdvanceTim.c文件:
#include "bsp_AdvanceTim.h"
#include "bsp_SysTick.h"
  // 输出比较通道 GPIO 初始化
  // 输出比较通道互补通道 GPIO 初始化
  // 输出比较通道刹车通道 GPIO 初始化
        // BKIN引脚默认先输出低电平
/* ----------------   PWM信号 周期和占空比的计算--------------- */
// ARR :自动重装载寄存器的值
// CLK_cnt:计数器的时钟,等于 Fck_int / (psc+1) = 72M/(psc+1)
// PWM 信号的周期 T = (ARR+1) * (1/CLK_cnt) = (ARR+1)*(PSC+1) / 72M
// 占空比P=CCR/(ARR+1)
  // 开启定时器时钟,即内部时钟CK_INT=72M
/*--------------------时基结构体初始化-------------------------*/
        // 自动重装载寄存器的值,累计TIM_Period+1个频率后产生一个更新或者中断
        //TIM_TimeBaseStructure.TIM_Period=ADVANCE_TIM_PERIOD;
        // 驱动CNT计数器的时钟 = Fck_int/(psc+1)
        // 时钟分频因子 ,配置死区时间时需要用到
        // 计数器计数模式,设置为向上计数
        // 重复计数器的值,没用到不用管
        // 初始化定时器
        /*--------------------输出比较结构体初始化-------------------*/
        // 配置为PWM模式1
        // 输出使能
        // 互补输出使能
        // 设置占空比大小
        // 输出通道电平极性配置
        // 互补输出通道电平极性配置
        // 输出通道空闲电平极性配置
        // 互补输出通道空闲电平极性配置
        /*-------------------刹车和死区结构体初始化-------------------*/
        // 有关刹车和死区结构体的成员具体可参考BDTR寄存器的描述
        // 输出比较信号死区时间配置,具体如何计算可参考 BDTR:UTG[7:0]的描述
        // 这里配置的死区时间为152ns
        // 当BKIN引脚检测到高电平的时候,输出比较信号被禁止,就好像是刹车一样
        // 使能计数器
        // 主输出使能,当使用的是通用定时器时,这句不需要
void ADVANCE_TIM_Config(uint8_t direction)
        if(direction==COROTATION)
以下是bsp_AdvanceTim.h文件:
#ifndef __BSP_ADVANCETIME_H
#define __BSP_ADVANCETIME_H
#include "stm32f10x.h"
/************高级定时器TIM参数定义,只限TIM1和TIM8************/
// 当使用不同的定时器的时候,对应的GPIO是不一样的,这点要注意
// 这里我们使用高级控制定时器TIM1
#define            ADVANCE_TIM                   TIM1
#define            ADVANCE_TIM_APBxClock_FUN     RCC_APB2PeriphClockCmd
#define            ADVANCE_TIM_CLK               RCC_APB2Periph_TIM1
// PWM 信号的频率 F = TIM_CLK/{(ARR+1)*(PSC+1)}
#define            ADVANCE_TIM_PERIOD            (20000-1)
#define            ADVANCE_TIM_PSC               (72-1)
#define            ADVANCE_TIM_PULSE             ((ADVANCE_TIM_PERIOD+1)/2)
#define            ADVANCE_TIM_IRQ               TIM1_UP_IRQn
#define            ADVANCE_TIM_IRQHandler        TIM1_UP_IRQHandler
// TIM1 输出比较通道
#define            ADVANCE_TIM_CH1_GPIO_CLK      RCC_APB2Periph_GPIOA
#define            ADVANCE_TIM_CH1_PORT          GPIOA
#define            ADVANCE_TIM_CH1_PIN           GPIO_Pin_8
// TIM1 输出比较通道的互补通道
#define            ADVANCE_TIM_CH1N_GPIO_CLK      RCC_APB2Periph_GPIOB
#define            ADVANCE_TIM_CH1N_PORT          GPIOB
#define            ADVANCE_TIM_CH1N_PIN           GPIO_Pin_13
#define            ADVANCE_TIM_CH2_GPIO_CLK      RCC_APB2Periph_GPIOA
#define            ADVANCE_TIM_CH2_PORT          GPIOA
#define            ADVANCE_TIM_CH2_PIN           GPIO_Pin_9
// TIM1 输出比较通道的互补通道
#define            ADVANCE_TIM_CH2N_GPIO_CLK      RCC_APB2Periph_GPIOB
#define            ADVANCE_TIM_CH2N_PORT          GPIOB
#define            ADVANCE_TIM_CH2N_PIN           GPIO_Pin_14
#define            ADVANCE_TIM_CH3_GPIO_CLK      RCC_APB2Periph_GPIOA
#define            ADVANCE_TIM_CH3_PORT          GPIOA
#define            ADVANCE_TIM_CH3_PIN           GPIO_Pin_10
// TIM1 输出比较通道的互补通道
#define            ADVANCE_TIM_CH3N_GPIO_CLK      RCC_APB2Periph_GPIOB
#define            ADVANCE_TIM_CH3N_PORT          GPIOB
#define            ADVANCE_TIM_CH3N_PIN           GPIO_Pin_15
// TIM1 输出比较通道的刹车通道
#define            ADVANCE_TIM_BKIN_GPIO_CLK      RCC_APB2Periph_GPIOB
#define            ADVANCE_TIM_BKIN_PORT          GPIOB
#define            ADVANCE_TIM_BKIN_PIN           GPIO_Pin_12
#define                                                COROTATION        1
#define                                                REVERSAL        0
/**************************函数声明********************************/
void ADVANCE_TIM_Config(uint8_t direction);
#endif        /* __BSP_ADVANCETIME_H */
以下是bsp_motor.c文件
#include "bsp_motor.h"
void motor_run(uint8_t direction,uint8_t frequency)
        TIM1->ARR=100000/frequency;
        ADVANCE_TIM_Config( direction );
以下是bsp_motor.h文件
#ifndef _BSP_MOTOR_H
#define _BSP_MOTOR_H
void motor_run(uint8_t direction,uint8_t frequency);
#endif  /* _BSP_MOTOR_H */
GMT+8, 2026-11-22 15:37 , Processed in 0.046467 second(s), 24 queries , Gzip On.
