查看: 19552|回复: 2
用mini外接了一个MAX31865模块出了问题
发表于 2018-4-19 17:02:32 | 显示全部楼层 |阅读模式
有人用过MAX31865模块吗,
我往配置寄存器里写入0xD1,读取出来的却是0xD9
然后读取RTD寄存器得到的值一直是FF
下面是代码
MAIN.c
#include "stm32f10x.h"
#include "./spi/bsp_spi.h"
#include "./usart/bsp_usart_dma.h"
#include "./max31865/bsp_max31865.h"
uint8_t read_temp_HIGH;
uint8_t read_temp_LOW;
uint16_t read_temp;
SPI_MAX31865_Config();
DEBUG_UART_Config();
USARTx_DMA_Config();
MAX31865_SendData(MAX31865_Configuration_Write,0xd1);//写0xd1(1101_0001)到配置寄存器:3-wire RTD,50Hz filter select
read_temp = MAX31865_ReceiveData(MAX31865_Configuration_Read);
read_temp_HIGH = MAX31865_ReceiveData(MAX31865_RTD_MSB_Read);
read_temp_LOW = MAX31865_ReceiveData(MAX31865_RTD_LSB_Read);
  read_temp = (read_temp_HIGH << 8) | read_temp_LOW;
printf("%x\r\n ",read_temp);
while(1);
/******** end of file *********/
SPI.c
void SPI_MAX31865_Config(void)
SPI_InitTypeDef SPI_InitStructure;
/* 第一步:初始化GPIO */
SPI_MAX31865_GPIO_APBxClkCmd(SPI_MAX31865_GPIO_CLK, ENABLE);
//打开SPI外设的时钟
SPI_MAX31865_APBxClkCmd(SPI_MAX31865_CLK, ENABLE);
//将SPI的GPIO配置为推挽复用模式
GPIO_InitStructure.GPIO_Pin = SPI_MAX31865_SCK_GPIO_PIN;
GPIO_Init(SPI_MAX31865_SCK_GPIO_PORT, &GPIO_InitStructure);
//MOSI
GPIO_InitStructure.GPIO_Pin = SPI_MAX31865_MOSI_GPIO_PIN;
GPIO_Init(SPI_MAX31865_MOSI_GPIO_PORT, &GPIO_InitStructure);
  //MISO
GPIO_InitStructure.GPIO_Pin = SPI_MAX31865_MISO_GPIO_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(SPI_MAX31865_MISO_GPIO_PORT, &GPIO_InitStructure);
//CS 软件控制
GPIO_InitStructure.GPIO_Pin = SPI_MAX31865_CS_GPIO_PIN;
GPIO_Init(SPI_MAX31865_CS_GPIO_PORT, &GPIO_InitStructure);
/* 初始化DRDY标志位 */
/* 第一步,打开外设的时钟 */
MAX31865_DRDY_APBxClkCmd(MAX31865_DRDY_GPIO_CLK, ENABLE);
/* 第二步, 配置外设初始化结构体 */
GPIO_InitStructure.GPIO_Pin = MAX31865_DRDY_GPIO_PIN;
/* 第三步, 调用外设初始化函数,把配置好的结构体成员写到寄存器里面 */
GPIO_Init(MAX31865_DRDY_GPIO_PORT, &GPIO_InitStructure);
//配置SPI工作模式
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CRCPolynomial = 0;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_Init(SPI_MAX31865x,&SPI_InitStructure);
SPI_Cmd(SPI_MAX31865x,ENABLE);
uint32_t time_out = 10000;
uint8_t SPI_TimeOut_CallBack(uint8_t data)
printf("\r\nSPI 检测超时,错误代码:%d",data);
return 0;
// 发送一个字节
uint8_t SPI_MAX31865_Send_Data(uint8_t data)
uint8_t read_temp;
time_out = SPI_MAX31865_WAIT_TIMEOUT;
/* 检测TXE */
while (SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_TXE) == RESET )
  //超时
  if(time_out-- == 0)
   return SPI_TimeOut_CallBack(1);
SPI_I2S_SendData(SPI1,data);
/* 检测RNXE */
  //超时
  if(time_out-- == 0)
   return SPI_TimeOut_CallBack(2);
read_temp = (uint8_t)SPI_I2S_ReceiveData(SPI1);
return read_temp;
//接收一个字节
uint8_t SPI_MAX31865_Receive_Data(void)
return SPI_MAX31865_Send_Data(0xFF);
MAX31865.c
/* 向MAX31865发送数据 */
void MAX31865_SendData(uint8_t addr , uint8_t data)
SPI_MAX31865_CS_LOW;
SPI_MAX31865_Send_Data(addr);
SPI_MAX31865_Send_Data(data);
SPI_MAX31865_CS_HIGH;
/* 从MAX31865读取数据 */
uint8_t MAX31865_ReceiveData(uint8_t addr)
uint8_t data;
data = SPI_MAX31865_Receive_Data();
return data;
发表于 2018-4-20 09:04:51 | 显示全部楼层
没用过,帮顶
 楼主| 发表于 2018-4-20 14:58:50 | 显示全部楼层
问题解决了~,我把地址宏MAX31865_RTD_MSB_Read和MAX31865_RTD_LSB_Read设置错了,上面的程序没问题~
GMT+8, 2026-11-23 14:13 , Processed in 0.041624 second(s), 24 queries , Gzip On.
