查看: 27146|回复: 4
pwm输出问题
发表于 2018-5-23 18:43:08 | 显示全部楼层 |阅读模式
用的是stm32F429的开发板,按照上面 想让PC6,PA5产生pwm波 ,但是为什么只有PA5有波形 ,PC6没有 是什么原因啊
void TIM2_PWM_Init(void)
  GPIO_InitTypeDef GPIO_Init_structure;
        TIM_TimeBaseInitTypeDef TIM_TimeBase_structure;
        TIM_OCInitTypeDef  TIM_OCInit_structure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
        //定时器复用引脚
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource5,GPIO_AF_TIM2);
        GPIO_Init_structure.GPIO_Pin=GPIO_Pin_5 ;
        GPIO_Init_structure.GPIO_Mode=GPIO_Mode_AF;
        GPIO_Init_structure.GPIO_OType=GPIO_OType_PP;
        GPIO_Init_structure.GPIO_PuPd=GPIO_PuPd_NOPULL;
  GPIO_Init_structure.GPIO_Speed=GPIO_High_Speed;
        GPIO_Init(GPIOA,&GPIO_Init_structure);
        TIM_TimeBase_structure.TIM_Period=9000-1;
        TIM_TimeBase_structure.TIM_Prescaler=900-1;
        TIM_TimeBase_structure.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBase_structure.TIM_CounterMode=TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM2,&TIM_TimeBase_structure);
        TIM_OCInit_structure.TIM_OCMode=TIM_OCMode_PWM1;
        TIM_OCInit_structure.TIM_OutputState=TIM_OutputState_Enable;
  TIM_OCInit_structure.TIM_Pulse = 3000-1;
        TIM_OCInit_structure.TIM_OCPolarity=TIM_OCPolarity_High;
        TIM_OC1Init(TIM2,&TIM_OCInit_structure);
        TIM_OC1PreloadConfig(TIM2,TIM_OCPreload_Enable);//通道一
//        TIM_OC2Init(TIM2,&TIM_OCInit_structure);
//        TIM_OC2PreloadConfig(TIM28,TIM_OCPreload_Enable);//通道三
        TIM_Cmd(TIM2,ENABLE);//时钟使能
void TIM8_PWM_Init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8,ENABLE);
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
        //定时器复用引脚
        GPIO_PinAFConfig(GPIOC,GPIO_PinSource6,GPIO_AF_TIM8);
        GPIO_Init_structure.GPIO_Pin=GPIO_Pin_6 ;
        GPIO_Init(GPIOC,&GPIO_Init_structure);
        TIM_TimeBaseInit(TIM8,&TIM_TimeBase_structure);
        TIM_OCInit_structure.TIM_OCMode=TIM_OCMode_PWM2;
        TIM_OC1Init(TIM8,&TIM_OCInit_structure);
        TIM_OC1PreloadConfig(TIM8,TIM_OCPreload_Enable);//通道一
        TIM_Cmd(TIM8,ENABLE);//时钟使能
 楼主| 发表于 2018-5-23 18:44:01 | 显示全部楼层
//部分 是注释掉了
发表于 2018-5-24 09:01:17 | 显示全部楼层
看看PC6是不是接到板子其它芯片了
发表于 2018-5-24 17:40:41 | 显示全部楼层
去查查手册,看看这两个管脚有没有定时器功能
发表于 2018-8-21 21:02:15 | 显示全部楼层
你这是控制两个步进电机吗
GMT+8, 2026-11-24 04:14 , Processed in 0.043804 second(s), 24 queries , Gzip On.
