查看: 20468|回复: 1
ADC
发表于 2018-10-25 17:44:20 | 显示全部楼层 |阅读模式
#define CR2_EXTTRIG_SWSTART_Set     ((uint32_t)0x00500000)
void ADC_SoftwareStartConvCmd(ADC_TypeDef* ADCx, FunctionalState NewState)
  /* Check the parameters */
  assert_param(IS_ADC_ALL_PERIPH(ADCx));
  assert_param(IS_FUNCTIONAL_STATE(NewState));
  if (NewState != DISABLE)
    /* Enable the selected ADC conversion on external event and start the selected
       ADC conversion */
    ADCx->CR2 |= CR2_EXTTRIG_SWSTART_Set;
    /* Disable the selected ADC conversion on external event and stop the selected
       ADC conversion */
    ADCx->CR2 &= CR2_EXTTRIG_SWSTART_Reset;
这里“#define CR2_EXTTRIG_SWSTART_Set     ((uint32_t)0x00500000)”把ADC_CR2的位22SWSTART和位20EXTTRIG都使能了,为什么呀?
发表于 2018-10-26 08:45:52 | 显示全部楼层
设置为软件使能和外部触发,跟宏的字面意思一致
GMT+8, 2026-11-22 10:35 , Processed in 0.038482 second(s), 24 queries , Gzip On.
