查看: 22638|回复: 2
求助:STM32 SPI读不到数据
发表于 2018-12-21 15:15:32 | 显示全部楼层 |阅读模式
ARM芯片是STM32F103RE,要读取的芯片为SCC2230。
SCC2230的CS接PC5,SCK接PA5,MISO接PA6,MOSI接PA7。中间都通过电阻隔离。
源码如下:
void scc2230_init(void)
    SPI_InitTypeDef  SPI_InitStructure;
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC, ENABLE );
    RCC_APB2PeriphClockCmd( RCC_APB2Periph_SPI1,  ENABLE );
    //SCK
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    //MISO
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
    //MOSI
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
    GPIO_Init(GPIOA, &GPIO_InitStructure);//3õê¼»ˉGPIO
   //CS
    GPIO_InitStructure.GPIO_Pin =GPIO_Pin_5;
    GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
     GPIO_SetBits(GPIOC,GPIO_Pin_5);
    SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
    SPI_InitStructure.SPI_CRCPolynomial = 7;
    SPI_Init(SPI1, &SPI_InitStructure);
    SPI_Cmd(SPI1, ENABLE);
    uint16_t rcv_scc1=0;
    uint16_t rcv_scc2=0;
    int rcv_data32=0;
   scc2230_init();
     //SCC2230
        GPIO_ResetBits(GPIOC,GPIO_Pin_5);
        while(SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
        SPI_I2S_SendData(SPI1, 0xFF);
        while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
//        while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_BSY) == SET);
        rcv_scc1 = SPI_I2S_ReceiveData(SPI1);
        rcv_scc2 = SPI_I2S_ReceiveData(SPI1);
        rcv_data32 = (rcv_scc1<<16) + rcv_scc2;
问题是:发送和接收状态查询都会死循环。如果将查询去掉,读到的数据也是0。
请大家帮忙看看,谢谢!
发表于 2018-12-22 08:48:00 | 显示全部楼层
你检查下时序与极性
 楼主| 发表于 2018-12-22 15:46:40 | 显示全部楼层
Brave000 发表于 2018-12-22 08:48
你检查下时序与极性
谢谢您的回答,能再详细一些吗?没有示波器
GMT+8, 2026-11-22 15:17 , Processed in 0.047693 second(s), 25 queries , Gzip On.
