查看: 23801|回复: 1
关于invalid operands to binary
发表于 2019-4-13 21:03:59 | 显示全部楼层 |阅读模式
【code】
void MY_NVIC_Init(u8 NVIC_PreemptionPriority,u8 NVIC_SubPriority,u8 NVIC_Channel,u8 NVIC_Group)
    u8 temp;
    u8 IPRADDR=NVIC_Channel/4;                        //ÿ×éÖ»ÄÜ´æ4¸ö,µÃµ½×鵨ַ
    u8 IPROFFSET=NVIC_Channel%4;                  //ÔÚ×éÄ򵀮«ÒÆ
    IPROFFSET=IPROFFSET*8+4;                        //µÃµ½Æ«ÒƵÄÈ·ÇÐλÖÃ
    MY_NVIC_PriorityGroupConfig(NVIC_Group);  //ÉèÖ÷Ö×é
    temp=NVIC_PreemptionPriority<<(4-NVIC_Group);
    temp|=NVIC_SubPriority&(0x0f>>NVIC_Group);
    temp&=0xf;//&#200;&#161;&#181;&#205;&#203;&#196;&#206;&#187;
    if(NVIC_Channel<32)NVIC->ISER[0]|=1<<NVIC_Channel;           //使能中断位
    else NVIC->ISER[1]|=1<<(NVIC_Channel-32);
    NVIC->IP |= temp<<IPROFFSET;出错行     invalid operands to binary    expression (‘volatile uint8_t 【240】’and ‘int’)
typedef struct
  __IO uint32_t ISER[8];                      /*!< Offset: 0x000  Interrupt Set Enable Register           */
       uint32_t RESERVED0[24];
  __IO uint32_t ICER[8];                      /*!< Offset: 0x080  Interrupt Clear Enable Register         */
       uint32_t RSERVED1[24];
  __IO uint32_t ISPR[8];                      /*!< Offset: 0x100  Interrupt Set Pending Register          */
       uint32_t RESERVED2[24];
  __IO uint32_t ICPR[8];                      /*!< Offset: 0x180  Interrupt Clear Pending Register        */
       uint32_t RESERVED3[24];
  __IO uint32_t IABR[8];                      /*!< Offset: 0x200  Interrupt Active bit Register           */
       uint32_t RESERVED4[56];
  __IO uint8_t  IP[240];                      /*!< Offset: 0x300  Interrupt Priority Register (8Bit wide) */
       uint32_t RESERVED5[644];
  __O  uint32_t STIR;                         /*!< Offset: 0xE00  Software Trigger Interrupt Register     */
}  NVIC_Type;
【/code】
没弄懂怎么改动
发表于 2019-4-23 14:09:05 | 显示全部楼层
要进行类型转换
GMT+8, 2026-11-18 20:59 , Processed in 0.059802 second(s), 25 queries , Gzip On.
