查看: 23512|回复: 1
库和寄存器手册相反
发表于 2019-5-19 23:18:06 | 显示全部楼层 |阅读模式
各位大哥,不知道是我理解错了,还是其他原因为什么DMA_Init(DMA_Stream_TypeDef* DMAy_Streamx, DMA_InitTypeDef* DMA_InitStruct);里的结构体定义里的DMA_FIFOMode 的枚举手册里的不配套
/** @defgroup DMA_fifo_direct_mode
#define DMA_FIFOMode_Disable              ((uint32_t)0x00000000)
#define DMA_FIFOMode_Enable               ((uint32_t)0x00000004)
这是库里的
Bit 2 DMDIS: Direct mode disable
This bit is set and cleared by software. It can be set by hardware.
0: Direct mode enabled
1: Direct mode disabled
This bit is protected and can be written only if EN is ‘0’.
This bit is set by hardware if the memory-to-memory mode is selected (DIR bit in
DMA_SxCR are “10”) and the EN bit in the DMA_SxCR register is ‘1’ because the direct
mode is not allowed in the memory-to-memory configuration.
手册里的
 楼主| 发表于 2019-5-19 23:18:57 | 显示全部楼层
救救孩子,是不是我理解错误或手册查的不对应
GMT+8, 2026-10-7 06:36 , Processed in 0.039769 second(s), 25 queries , Gzip On.
