查看: 47024|回复: 3
老师帮忙看看,哪里出的问题?
发表于 2021-2-7 23:00:19 | 显示全部楼层 |阅读模式
老师快来!老师快来!老师快来!老师快来!老师快来!老师快来!老师快来!老师快来!老师快来!老师快来!老师快来!老师快来!老师快来!老师快来!
按键控制LED灯开关,我把KEY和LED的初始化配置文件分开写没事,但是合在一起就不可以,MINI板子上的两个LED灯一直亮着,老师帮忙看看哪里出了问题,
  1. #include "stm32f10x.h"
  2. #include "./bsp_key/bsp_key.h"
  3. void delay(uint32_t count)
  4. {
  5.         for(;count!=0;count--);
  6. }
  7. int main()
  8. {
  9.         LED_GPIO_Config();
  10.         KEY_GPIO_Config();
  11.         if(Key_Scan(KEY1_GPIO_PORT,KEY1_GPIO_Pin)==KEY_ON)
  12.         {
  13.                 /* LED1 TOGGLE*/
  14.                 LED1_TOGGLE;
  15.         }
  16.         if(Key_Scan(KEY2_GPIO_PORT,KEY2_GPIO_Pin)==KEY_ON)
  17.         {
  18.                 /* LED2 TOGGLE*/
  19.                 LED2_TOGGLE;
  20.         }
  21. }
  1. #include "./bsp_key/bsp_key.h"
  2. void KEY_GPIO_Config(void)
  3. {  GPIO_InitTypeDef GPIO_InitStruct;
  4.         //开始按键时钟使能
  5.         RCC_APB2PeriphClockCmd(KEY1_GPIO_CLK|KEY2_GPIO_CLK,ENABLE);
  6.         //配置外设相关的初始化结构体
  7.
  8.         GPIO_InitStruct.GPIO_Pin=KEY1_GPIO_Pin;
  9.         GPIO_InitStruct.GPIO_Mode=GPIO_Mode_IN_FLOATING;
  10.         //输入不用配置速度
  11.         GPIO_Init(KEY1_GPIO_PORT,&GPIO_InitStruct);
  12.
  13.         GPIO_InitStruct.GPIO_Pin=KEY2_GPIO_Pin;
  14.         GPIO_InitStruct.GPIO_Mode=GPIO_Mode_IN_FLOATING;
  15.         GPIO_Init(KEY2_GPIO_PORT,&GPIO_InitStruct);
  16. }
  17. //按键扫描函数
  18. uint8_t Key_Scan(GPIO_TypeDef* GPIOx,uint16_t GPIO_Pin)
  19. {
  20.         if(GPIO_ReadInputDataBit(GPIOx,GPIO_Pin)==KEY_ON)
  21.         {
  22.                 while(GPIO_ReadInputDataBit(GPIOx,GPIO_Pin)==KEY_ON);
  23.                 return KEY_ON;
  24.
  25.         }
  26.         else
  27.                 return KEY_OFF;
  28. }
  29. void LED_GPIO_Config(void)
  30. {
  31.         GPIO_InitTypeDef GPIO_InitStruct;
  32.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOC,ENABLE);
  33.         GPIO_InitStruct.GPIO_Pin=GPIO_Pin_2;
  34.         GPIO_InitStruct.GPIO_Mode=GPIO_Mode_Out_PP;
  35.         GPIO_InitStruct.GPIO_Speed=GPIO_Speed_10MHz;
  36.         GPIO_Init(GPIOC,&GPIO_InitStruct);
  37.
  38.         GPIO_InitStruct.GPIO_Pin=GPIO_Pin_3;
  39.         GPIO_Init(GPIOC,&GPIO_InitStruct);
  40. }
  1. #ifndef __bsp_key_H
  2. #define __bsp_key_H
  3. #include "stm32f10x.h"
  4. #define KEY1_GPIO_CLK    RCC_APB2Periph_GPIOA
  5. #define KEY1_GPIO_PORT   GPIOA
  6. #define KEY1_GPIO_Pin    GPIO_Pin_0
  7. #define KEY2_GPIO_CLK    RCC_APB2Periph_GPIOC
  8. #define KEY2_GPIO_PORT   GPIOC
  9. #define KEY2_GPIO_Pin    GPIO_Pin_13
  10. #define KEY_ON  1
  11. #define KEY_OFF 0
  12. //C语言知识点,^:两个数相同,为0,不同为1(异或)
  13. #define digitalTOGGLE(p,i)    {p->ODR ^=i;}
  14. #define LED1_TOGGLE      digitalTOGGLE(GPIOC,GPIO_Pin_2)
  15. #define LED2_TOGGLE      digitalTOGGLE(GPIOC,GPIO_Pin_3)
  16. void LED_GPIO_Config(void);
  17. void KEY_GPIO_Config(void);
  18. uint8_t Key_Scan(GPIO_TypeDef* GPIOx,uint16_t GPIO_Pin);
  19. #endif /*__bsp_key_h  */
我查了好久找不到错误。
发表于 2021-2-8 11:40:04 | 显示全部楼层
你这代码有问题啊,无论是使用中断控制还是使用CPU循环扫描按键,都要在结尾加一个while循环。你这个代码应该是用CPU循环扫描控制,你把main函数里的两个if语句加到while(1)循环里,循环条件一直为1应该就可以了。你这个程序直接执行完毕了,LED引脚是低电平,直接就会点亮LED,不会等你按下按键来改变。如果解决了就告诉我一声。
 楼主| 发表于 2021-2-8 13:20:01 | 显示全部楼层
谢谢老师,我懂了,原来我的while(1)提前回家过年了
 楼主| 发表于 2021-2-8 17:43:43 | 显示全部楼层
清风抚琴 发表于 2021-2-8 11:40
你这代码有问题啊,无论是使用中断控制还是使用CPU循环扫描按键,都要在结尾加一个while循环。你这个代码应 ...
加上while(1){},可以控制了,谢谢指点
GMT+8, 2026-11-22 12:42 , Processed in 0.042818 second(s), 25 queries , Gzip On.
