查看: 1893|回复: 3
求助:关于触摸屏驱动芯片gt917s配置写入
发表于 2025-10-29 09:24:53 | 显示全部楼层 |阅读模式
peizhigt917s该如何写配置位信息, 就是数组那段,按照手册上说的,最后最后一位是en写入位,倒数两位是求和校验位,但是我怎么都得不出来这个结果,想改一个配置信息根本改不了。uint8_t CTP_CFG_GT917S[] ={
  0x97,0x20,0x03,0xE0,0x01,0x0A,0x35,0x04,0x00,0x69,
  0x09,0x0F,0x50,0x32,0x33,0x11,0x00,0x32,0x11,0x11,
  0x28,0x8C,0xAA,0xDC,0x58,0x04,0x00,0x00,0x1E,0x3C,
  0x00,0x00,0x00,0x31,0x00,0x00,0x00,0x00,0x00,0x40,
  0x32,0x00,0x00,0x50,0x38,0x00,0x8D,0x20,0x16,0x4E,
  0x4C,0x7C,0x05,0x28,0x3E,0x28,0x0D,0x43,0x24,0x00,
  0x01,0x39,0x6B,0xC0,0x94,0x84,0x2D,0x00,0x54,0xB0,
  0x41,0x9D,0x49,0x8D,0x52,0x7F,0x5A,0x75,0x62,0x6C,
  0x42,0x50,0x14,0x00,0x00,0x00,0x00,0xF0,0x50,0x3C,
  0x88,0x88,0x27,0x50,0x3C,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x50,0x00,0x02,0x78,
  0x0A,0x50,0xFF,0xE4,0x04,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x3C,0xB0,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x56,0xA2,0x07,0x50,0x1E,
  0x05,0x06,0x07,0x08,0x09,0x0A,0x0B,0x0C,0x0D,0x0E,
  0x0F,0x10,0x12,0x15,0x16,0x17,0x18,0x19,0x1A,0x1B,
  0x1D,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  0xFF,0xFF,0x1F,0x1E,0x1D,0x1C,0x1B,0x1A,0x19,0x18,
  0x17,0x15,0x14,0x13,0x12,0xFF,0xFF,0xFF,0xFF,0xFF,
  0xFF,0xFF,0xFF,0xFF,0x00,0x30,0x7F,0x7F,0x7F,0xFF,
  0x54,0x64,0x00,0x80,0x46,0x07,0x50,0x3C,0x32,0x14,
  0x0A,0x64,0x32,0x00,0x00,0x00,0x00,0x11,0x02,0x62,
  0x32,0x03,0x14,0x50,0x0C,0xE2,0x14,0x50,0x00,0x54,
  0x10,0x00,0x32,0xA2,0x07,0x64,0xA4,0xB6,0x01
};这里贴上野火提供历程的数组,有没有人能告诉我A4B6怎么来的,我怎么求和都求不出来
发表于 2025-11-5 11:53:32 | 显示全部楼层
是以前买的屏幕还是最近买的屏幕,如果是最近买的屏幕是911或者1151的,可以店铺问下技术支持要下对应的CFG文件,
如果是以前买的屏幕也到店铺问下看能不能找到对的CFG文件,例程上可能是弄混乱的
GMT+8, 2026-11-18 19:38 , Processed in 0.136768 second(s), 24 queries , Gzip On.
