查看: 1606|回复: 3
[求助] 官方虚拟机加上官方的 full_SDK 编译不过
发表于 2025-12-15 13:51:17 | 显示全部楼层 |阅读模式
我尝试用官方虚拟机编译 野火官方提供的RK3588 结果编译出错, 我尝试用虚拟机自带的/home/lubancat/LubanCat_SDK,也无法编译通过,请问这是什么原因,尝试解决了 还有新的问题
dpkg-deb: 正在 '../linux-image-4.19.232-dbg_4.19.232-1_arm64.deb' 中构建软件包 'linux-image-4.19.232-dbg'。
dpkg-genbuildinfo --build=binary
dpkg-genchanges --build=binary >../linux-4.19.232_4.19.232-1_arm64.changes
dpkg-genchanges: info: binary-only upload (no source code included)
dpkg-source --after-build .
dpkg-buildpackage: info: binary-only upload (no source included)
Running build_kerneldeb succeeded.
============Start building kernel============
TARGET_ARCH          =arm64
TARGET_KERNEL_CONFIG =lubancat2_defconfig
TARGET_KERNEL_DTS    =rk356x-lubancat-rk_series
TARGET_KERNEL_CONFIG_FRAGMENT =
# configuration written to .config
scripts/kconfig/conf  --syncconfig Kconfig
  CALL    scripts/checksyscalls.sh
  DTC     arch/arm64/boot/dts/rockchip/rk356x-lubancat-rk_series.dtb
  CHK     include/generated/compile.h
  GZIP    kernel/config_data.gz
  LZ4C    arch/arm64/boot/Image.lz4
  Image:  kernel.img is ready
  Building modules, stage 2.
  MODPOST 9 modules
reverse data at first time
found ./arch/arm64/boot/dts/rockchip/.rk356x-lubancat-rk_series.dtb.dts.tmp
  Image:  resource.img (with rk356x-lubancat-rk_series.dtb logo.bmp logo_kernel.bmp) is ready
  Image:  boot.img (with Image  resource.img) is ready
  Image:  zboot.img (with Image.lz4  resource.img) is ready
Generate extLinuxBoot image start
mke2fs 1.45.5 (07-Jan-2020)
Discarding device blocks: done
Creating filesystem with 32768 4k blocks and 32768 inodes
Allocating group tables: done
Writing inode tables: done
Copying files into the device: done
Writing superblocks and filesystem accounting information: done
Running build_extboot succeeded.
Skipping build_toolchain for missing configs:  RK_CFG_TOOLCHAIN.
=========Start building ubuntu for arm64=========
==RK_ROOTFS_DEBUG:debug RK_ROOTFS_TARGET:xfce-full==
./build.sh: line 901: cd: ubuntu: No such file or directory
ERROR: Running build_ubuntu failed!
ERROR: exit code 1 from line 901:
    cd ubuntu
lubancat@lubancat-vm:~/LubanCat_SDK$
这是出错的内容
这是出错的内容
发表于 2025-12-17 08:59:32 | 显示全部楼层
虚拟机自带的sdk有点旧了,新拉一个看看有什么报错
GMT+8, 2026-10-3 15:56 , Processed in 0.109436 second(s), 28 queries , Gzip On.
