查看: 38711|回复: 2
关于捕获寄存器捕获不到正确数据?急求解答!!!
发表于 2014-8-5 08:34:04 | 显示全部楼层 |阅读模式
我写了一个用定时器3的1通道捕获一个PWM的周期,但是其得到的数据和实际相去甚远!
static void TIM4_Mode_Config(void)
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 999;
  TIM_TimeBaseStructure.TIM_Prescaler = 100-1;
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
这是定时器4用来产生一个PWM信号来给定时器3捕获,其频率即为:(72M/100)/1000=720Hz,T=1/f=1.38ms 用示波器观察其信号没有错误。
static void TIM3_GPIO_Config(void)
        /* éèÖÃTIM3CLK Îa 72MHZ */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  /* GPIOA and GPIOB clock enable */
  /*GPIOA Configuration: TIM3 channel 1 and 2 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6 | GPIO_Pin_7;
void NVIC_Config_TIM3Capture(void)
        NVIC_InitTypeDef  NVIC_InitStructure;
        NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
static void TIM3_Mode_Config(void)
        TIM_ICInitTypeDef  TIM_ICInitStructure;
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_TimeBaseStructure.TIM_Period = 5000-1;
        TIM_TimeBaseStructure.TIM_Prescaler = 719; //FreÎa20Hz
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
        TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
  TIM_ICInitStructure.TIM_ICFilter = 0; // ¶ÔêäèëDÅoÅÂË2¨
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; // éÏéyÑØ′¥·¢
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //¶Ôía2¿DÅoÅ·ÖÆμ
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //2»ê1óý»2æ′¥·¢
        TIM_ICInit(TIM3, &TIM_ICInitStructure);
  TIM_ITConfig(TIM3, TIM_IT_CC1, ENABLE);
        TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
        TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling;
  TIM_ITConfig(TIM3, TIM_IT_CC2, ENABLE);
        NVIC_Config_TIM3Capture();
  TIM_Cmd(TIM3, ENABLE);
void TIM3_Capture_Init(void)
        TIM3_GPIO_Config();
        TIM3_Mode_Config();
这是捕获定时器3的设置。
void TIM3_IRQHandler(void)
        if(TIM_GetITStatus(TIM3, TIM_IT_CC1) == SET)
                TIM_ClearITPendingBit(TIM3, TIM_IT_CC1);
                if(flag == 0)
                        TIM_SetCounter(TIM3, 0);
                        flag=1;
                else if(flag == 1)
                        flag=0;
                        printf("%d\n",TIM_GetCapture1(TIM3));
这是中断函数,按道理说第一次上升沿我将CNT置0,第二次上升沿采集到CCR的值TIM_GetCapture1(TIM3)应该等于定时器4产生的周期1.38ms,即CCR的值应该等于138,但是CCR取出来的值每次都等于88或89,为什么相差这么多呢?
发表于 2014-8-5 09:17:55 | 显示全部楼层
重新计算一下你对定时器3的分频有没有计算正确,检查下公式
 楼主| 发表于 2014-8-5 09:54:30 | 显示全部楼层
即72M/720 = 0.1M = 100000
那么寄存器为138不就是138/100000=1.38ms;
寄存器为89时不就是89/100000=0.89ms
GMT+8, 2026-10-4 10:07 , Processed in 0.035708 second(s), 24 queries , Gzip On.
