查看: 17388|回复: 4
按键控制DA输出电压
发表于 2015-1-9 21:14:12 | 显示全部楼层 |阅读模式
小白一枚。如何使用按键控制DA模块输出0-3.3v模拟电压,步长0.5v。。求大神帮忙!
发表于 2015-1-10 09:05:51 | 显示全部楼层
参考一下野火的dac正弦波例程
 楼主| 发表于 2015-1-10 22:50:01 | 显示全部楼层
#define DAC_DHR12R1_Address      0x40007408//0x40007420
/* 2¨DÎêy¾Y ---------------------------------------------------------*/
const uint16_t Sine12bit[8] = {0x0,0x26c,0x4d8,0x745,0x9b1,0xc1c,0xe89,0xffd
uint32_t DualSine12bit=0;
  * @brief  ê1ÄüDACμÄê±Öó£¬3õê¼»ˉGPIO
  * @param  ÎT
  * @retval ÎT
static void DAC_Config(void)
        DAC_InitTypeDef  DAC_InitStructure;
  /* ê1ÄüGPIOAê±Öó */
        /* ê1ÄüDACê±Öó */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
  /* DACμÄGPIOÅäÖã¬Ä£Äaêäèë */
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_4;
  /* ÅäÖÃDAC í¨μà1 */
  DAC_InitStructure.DAC_Trigger = DAC_Trigger_Software;                                                //′¥·¢Ô′
  DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;        //2»ê1óÃ2¨Dη¢éúÆ÷
  DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable;        //2»ê1óÃDACêä3ö»o3å
  DAC_Init(DAC_Channel_1, &DAC_InitStructure);
  /* ê1Äüí¨μà1 óéPA4êä3ö */
  DAC_Cmd(DAC_Channel_1, ENABLE);
  DAC_SoftwareTriggerCmd(DAC_Channel_1,ENABLE);
  /* ê1ÄüDACμÄDMAÇëÇó */
  DAC_DMACmd(DAC_Channel_1, ENABLE);
  * @brief  ÅäÖÃKEY
  * @param  ÎT
  * @retval ÎT
void KEY_GPIO_Config(void)
        /*¿aÆô°′¼ü¶Ë¿ú£¨PA£©μÄê±Öó*/
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
//        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  * @brief  ÅäÖÃDMA
  * @param  ÎT
  * @retval ÎT
static void DAC_DMA_Config(void)
        DMA_InitTypeDef  DMA_InitStructure;
        /* ê1ÄüDMA2ê±Öó */
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
        /* ÅäÖÃDMA2 */
  DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_DHR12R1_Address;                                        //íaéèêy¾YμØÖ·
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&DualSine12bit ;                                //Äú′æêy¾YμØÖ· DualSine12bit
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;        //êy¾Y′«êä·½ÏòÄú′æÖáíaéè
  DMA_InitStructure.DMA_BufferSize = 2;        //»o′æ′óD¡Îa2×Ö½ú
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;                                //íaéèêy¾YμØÖ·1춨
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;        //Äú′æêy¾YμØÖ·×ÔÔö
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;        //íaéèêy¾YòÔ×ÖÎaμ¥λ
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;                                        //Äú′æêy¾YòÔ×ÖÎaμ¥λ
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;        //Ñ-»·Ä£ê½
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;        //¸ßDMAí¨μàóÅÏè¼¶
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;        //·ÇÄú′æÖáÄú′æÄ£ê½
  DMA_Init(DMA2_Channel3, &DMA_InitStructure);
  /* ê1ÄüDMA2-14í¨μà */
  DMA_Cmd(DMA2_Channel3, ENABLE);
//°′¼üé¨Ãè
uint8_t Key_Scan(GPIO_TypeDef* GPIOx,u16 GPIO_Pin)
        /*¼ì2aêÇ·ñóD°′¼ü°′Ï */
        if(GPIO_ReadInputDataBit(GPIOx,GPIO_Pin) == KEY_ON )
                /*Ñóê±Ïû¶¶*/
                Key_Delay(10000);
                        /*μè′y°′¼üêí·Å */
                        while(GPIO_ReadInputDataBit(GPIOx,GPIO_Pin) == KEY_ON);
                        return         KEY_ON;
                        return KEY_OFF;
                return KEY_OFF;
//°′¼üD
void Key_Delay(__IO u32 nCount)
        for(; nCount != 0; nCount--);
  * @brief  DAC3õê¼»ˉoˉêy
  * @param  ÎT
  * @retval ÎT
void DAC_Mode_Init(void)
        uint32_t Idx = 0;
        DAC_Config();
        DAC_DMA_Config();
        KEY_GPIO_Config();
                if( Key_Scan(GPIOA,GPIO_Pin_0) == KEY_ON ){
                        Idx++;
      DualSine12bit = Sine12bit[Idx];
                if(Idx==7)
                        Idx=0;
能看一下错误在哪吗?烧到板子里没反应。
 楼主| 发表于 2015-1-10 22:50:30 | 显示全部楼层
flyleaf 发表于 2015-1-10 09:05
参考一下野火的dac正弦波例程
  * @param  ÎT
  * @retval ÎT
  /* ê1ÄüGPIOAê±Öó */
        /* ê1ÄüDACê±Öó */
  /* ÅäÖÃDAC í¨μà1 */
  * @brief  ÅäÖÃKEY
  * @param  ÎT
  * @retval ÎT
  * @brief  ÅäÖÃDMA
  * @param  ÎT
  * @retval ÎT
        /* ê1ÄüDMA2ê±Öó */
        /* ÅäÖÃDMA2 */
//°′¼üé¨Ãè
                /*Ñóê±Ïû¶¶*/
                Key_Delay(10000);
                        /*μè′y°′¼üêí·Å */
                        return         KEY_ON;
                        return KEY_OFF;
                return KEY_OFF;
//°′¼üD
  * @param  ÎT
  * @retval ÎT
        uint32_t Idx = 0;
        DAC_Config();
        DAC_DMA_Config();
        KEY_GPIO_Config();
                        Idx++;
                if(Idx==7)
                        Idx=0;
能看一下错误在哪吗?烧到板子里没反应。
 楼主| 发表于 2015-1-10 23:09:41 | 显示全部楼层
参考一下野火的dac正弦波例程
可能是我的DMA使用不正确。我把它去掉之后可以工作了,可是把0x0赋值给DAC->DHR12R1后,有二点多伏的电压,不知道为什么?而且步长也很小,please help!
  * @file    bsp_xxx.c
  * @author  fire
  * @version V1.0
  * @date    2013-xx-xx
  * @brief   adc1 ó|óÃbsp / DMA Ä£ê½
  * @attention
  * êμÑ鯽ì¨:ò°»e ISO-MINI STM32 ¿a·¢°å
  * ÂÛì3    :http://www.firebbs.cn
  * ìÔ±|    :http://firestm32.taobao.com
#include "bsp_dac.h"
//uint32_t DualSine12bit=0;
  * @param  ÎT
  * @retval ÎT
  /* ê1ÄüGPIOAê±Öó */
        /* ê1ÄüDACê±Öó */
  /* ÅäÖÃDAC í¨μà1 */
  * @brief  ÅäÖÃKEY
  * @param  ÎT
  * @retval ÎT
//°′¼üé¨Ãè
                /*Ñóê±Ïû¶¶*/
                Key_Delay(10000);
                        /*μè′y°′¼üêí·Å */
                        return         KEY_ON;
                        return KEY_OFF;
                return KEY_OFF;
//°′¼üD
  * @param  ÎT
  * @retval ÎT
        uint32_t Idx = 0;
        DAC_Config();
        KEY_GPIO_Config();
                        Idx++;
      DAC->DHR12R1 = Sine12bit[Idx];
                if(Idx==7)
                        Idx=0;
GMT+8, 2026-10-4 15:06 , Processed in 0.046481 second(s), 23 queries , Gzip On.
