查看: 28632|回复: 5
SPI与FLASH通信问题!!!!急!!
发表于 2015-2-6 16:57:00 | 显示全部楼层 |阅读模式
这是要读取FLASH的deviceID   程序读到第一个灯亮就死了。。。  谁能告诉我程序哪有问题吗  检查了半天了。。。
#include "stm32f10x.h"
#include "stdio.h"
#include "usart1.h"
#include "spi.h"
#include "led.h"
  * @brief  Ö÷oˉêy
  * @param  ÎT
  * @retval ÎT
u8 DeviceID = 0, FlashID = 0;
void Delay(__IO uint32_t nCount);
        LED_GPIO_Config();
        USART1_Config();
        printf("\r\n 这是一个2M串行flash(W25Q16)实验  \r\n");
        SPI_FLASH_InitConfig();
        LED1(ON);
        DeviceID = SPI_FLASH_ReadDeviceID();
        LED2(ON);
        printf("\r\n Device ID is 0x%X\r\n", DeviceID);
        LED3(ON);
        while(1);
  for(; nCount != 0; nCount--);
#include "spi.h"
#define PageSize 256
#define BUSY 0x01
#define W25Q_WriteEnable 0x06
#define W25Q_PowerDown 0xB9
#define W25Q_PageWrite 0x02
#define W25Q_ReadStatus 0x05
#define W25Q_DeviceID 0xAB
#define W25Q_ManufacturerID 0x90
#define W25Q_ReadData 0x03
#define W25Q_JEDECID 0X9F
void SPI_FLASH_InitConfig(void)
        SPI_InitTypeDef  SPI_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_SPI1, ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
        SPI_FLASH_CS_HIGH();
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
        SPI_Init(SPI1, &SPI_InitStructure);
        SPI_Cmd(SPI1, ENABLE);
u8 SPI_FLASH_ReadDeviceID(void)
        u8 t = 0;
        SPI_FLASH_CS_LOW();
        SPI_FLASH_SendByte(W25Q_DeviceID);
        SPI_FLASH_SendByte(0);
    t = SPI_FLASH_ReceiveByte();
        return t;
void SPI_FLASH_SendByte(u8 byte)
        while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET );
        SPI_I2S_SendData(SPI1, byte);
        while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == SET);
       SPI_I2S_ReceiveData(SPI1);
u8 SPI_FLASH_ReceiveByte(void)
        SPI_I2S_SendData(SPI1, 0);
        return SPI_I2S_ReceiveData(SPI1);
 楼主| 发表于 2015-2-6 17:02:30 | 显示全部楼层
但是当把void SPI_FLASH_SendByte(u8 byte)  改成u8  SPI_FLASH_SendByte(u8 byte)
u8 SPI_FLASH_ReadDeviceID(void) 这个函数里的  t = SPI_FLASH_ReceiveByte();  改成   t = SPI_FLASH_SendByte();
调试助手上就显示了  为什么啊。。。。
 楼主| 发表于 2015-2-6 17:03:20 | 显示全部楼层
u8 SPI_FLASH_ReadDeviceID(void) 这个函数里的  t = SPI_FLASH_ReceiveByte();  改成   t = SPI_FLASH_SendByte(0);
调试助手上就显示了  为什么啊。。。。 谁能告诉我。。。。。
发表于 2015-2-6 19:03:58 | 显示全部楼层
这么奇怪啊,看不出区别呢,你可以参考一下野火的spi flash程序,这个驱动写好了
 楼主| 发表于 2015-2-7 17:17:54 | 显示全部楼层
知道了。。。知道了。。。 我是把 SPI的预分频系数设置成2了   野火例程是4    如果设成2 当PCLK2最大72MHz时  SPI就是36MHz了 超过最大SPI最大的18MHz了。
发表于 2015-4-16 03:26:20 | 显示全部楼层
不开AFIO时钟也能用?
GMT+8, 2026-11-22 09:12 , Processed in 0.042619 second(s), 24 queries , Gzip On.
