查看: 28835|回复: 1
FM收音机
发表于 2015-3-26 13:01:54 | 显示全部楼层 |阅读模式
// RDA5807 ¼Ä′æÆ÷  D′
static uint8_t RDA_reg_data[8] =
   0xd0,0x00,  // 02H
   0x00,0x00,  // 03H
   0x00,0x40,  // 04H
   0x90,0x88,  // 05H
  * @brief  RDA5807_write_reg á¬DøD′¼Ä′æÆ÷
  * @param  ÎT
  * @retval ÎT
static void RDA5807_write_reg(void)
        uint8_t i;
        uint8_t ucAck;
        i2c_Start();
        i2c_SendByte(RDA5807M_SLAVE_ADDRESS | I2C_WR);
    ucAck = i2c_WaitAck();
        if (ucAck == 1)
                goto err_quit;
        for(i=0; i<8; i++)
                i2c_SendByte(RDA_reg_data);
                if (ucAck == 1)
                        goto err_quit;
err_quit:
        i2c_Stop();
  * @brief  RDA5807_read_reg á&#172;D&#248;&#182;á&#188;&#196;′&#230;&#198;÷
  * @param  &#206;T
  * @retval &#206;T
void RDA5807_read_reg(uint8_t *reg_buf)
        uint8_t i;
        uint8_t ucAck;
        i2c_Start();
        i2c_SendByte(RDA5807M_SLAVE_ADDRESS | I2C_RD);
        /* &#188;ì2aACK */
        if (ucAck == 1)
                goto err_quit;
        for (i = 0; i < 4; i++)
                reg_buf = i2c_ReadByte();
                if (i == 3)
                        i2c_NAck();
                        i2c_Ack();
err_quit:
        i2c_Stop();
  * @brief  RDA5807_power ê&#213;ò&#244;&#196;£&#191;éé&#207;μ&#231;£&#172;&#184;′&#206;&#187;
  * @param  &#206;T
  * @retval &#206;T
static void RDA5807_power(void)
         Delay_ms(50);
   RDA_reg_data[0] = 0x00;
   RDA_reg_data[1] = 0x02;
   RDA5807_write_reg();
   Delay_ms(10);
   // ê&#213;ò&#244;&#196;£&#191;é&#196;&#172;è&#207;2&#206;êy
   RDA_reg_data[0] = 0xd0;
   RDA_reg_data[1] = 0x01;
  * @brief  RDA5807_FM_seek ×&#212;&#182;ˉ&#209;°ì¨
  * @param  &#206;T
  * @retval &#206;T
static void RDA5807_FM_seek(void)
   uint8_t  reg_data[4] = {0x00, 0x00, 0x00, 0x00};
   RDA_reg_data[3] &= ~(1 << 4);
   RDA_reg_data[0] |=  (1 << 0);
   while(0 == (reg_data[0] & 0x40))
     Delay_ms(40);
     RDA5807_read_reg(reg_data);
   chan = reg_data[0] & 0x03;
   chan = reg_data[1] | (chan << 8);
   chan = chan << 6;
   printf("\r\n &#209;°ì¨3é1| \r\n");
   printf("μ±&#199;°1¤×÷&#198;μμ&#227;&#206;a£o%d" , chan);
   RDA_reg_data[2] = (chan >> 8) & 0xff;
   RDA_reg_data[3] = (chan & 0xff);
  * @brief  RDA5807_FM_Test ê&#213;ò&#244;&#187;ú&#196;£&#191;é2aê&#212;
  * @param  &#206;T
  * @retval &#206;T
void RDA5807_FM_Test(void)
        LED1_ON;
        LED2_ON;
        printf("\r\n rda5807m 2aê&#212;êμ&#209;é \r\n");
        if ( i2c_CheckDevice(RDA5807M_SLAVE_ADDRESS) == 0 )
                printf("\r\n rda5807m &#188;ì2a3é1| \r\n");
                printf("\r\n rda5807m &#188;ì2a2&#187;3é1| \r\n");
        RDA5807_power();
        printf("\r\n é&#207;μ&#231;3é1| \r\n");
        RDA5807_Volume_Set(5);
        RDA5807_Seek_Next();
                if( Key_Scan(GPIOC,GPIO_Pin_13) == KEY_ON  )
                        touch_even = E_SEEK_NEXT;
                        LED1_TOGGLE;
                if( Key_Scan(GPIOA,GPIO_Pin_0) == KEY_ON  )
                        touch_even = E_SEEK_PREV;
                        LED1_TOGGLE;
                even_process();
我是用野火案例里的FM收音机,写进去的,出现的现象是可以接收到广播,就是不能控制声音,而且KEY1可以使用,KEY2没用.触摸屏测试没问题.
发表于 2015-3-26 16:37:56 | 显示全部楼层
MINI:链接: http://pan.baidu.com/s/1pJr6bhD 密码: nwpt
ISO:链接: http://pan.baidu.com/s/1bbAxC 密码: 6vmf
重新下载例程,再测试看看
GMT+8, 2026-11-18 16:55 , Processed in 0.037353 second(s), 24 queries , Gzip On.
