查看: 20725|回复: 3
求教:mini板一直正常,突然不能进入DEBUG,下载可以
发表于 2015-8-19 00:28:28 | 显示全部楼层 |阅读模式
Build target 'Cortex-M3'
compiling 24l01.c...
linking...
Program Size: Code=26738 RO-data=594 RW-data=272 ZI-data=6544
FromELF: creating hex file...
"..\Output\Cortex-M3.axf" - 0 Error(s), 0 Warning(s).
Load "..\\Output\\Cortex-M3.AXF"
Set jtag Project File to "C:\Users\zhaoxudong\Desktop\Cortex-M3\Project\jtagSettings.ini"
jtag info:
DLL: V4.15n, compiled Jun 18 2010 19:55:09
Firmware: jtag ARM ARM compiled Nov 14 2012 22:34:52
Hardware: ARM.00
S/N : 308622870
Feature(s) : RDI,FlashDL,FlashBP,JFlash,GDBFULL
* jtag Info: TotalIRLen = 9, IRPrint = 0x0011
* jtag Info: Found Cortex-M3 r1p1, Little endian.
* jtag Info: TPIU fitted.
* jtag Info: ETM fitted.
* jtag Info:   FPUnit: 6 code (BP) slots and 2 literal slots
ROMTableAddr = 0xE00FF003
Target info:
Device: STM32F103VE
VTarget = 3.293V
State of Pins:
TCK: 1, TDI: 0, TDO: 1, TMS: 0, TRES: 1, TRST: 1
Hardware-Breakpoints: 6
Software-Breakpoints: 2048
Watchpoints:          4
JTAG speed: 2000 kHz
Full Chip Erase Done.
Programming Done.
Verify OK.
Application running ...
发表于 2015-8-19 09:01:44 | 显示全部楼层
最后的:Application running ...
显示程序是直接烧写到板子上的,不是debug,你会不会是弄错了。
 楼主| 发表于 2015-8-20 00:09:44 | 显示全部楼层
火哥,不是download,确实点的是dubeg,就是进不去,一直好好的
发表于 2015-8-20 09:09:03 | 显示全部楼层
把左下角的三档开关打到flash档位试试
GMT+8, 2026-10-19 18:56 , Processed in 0.033964 second(s), 23 queries , Gzip On.
