查看: 34120|回复: 8
STM32F103 点亮LED的另一种写法
发表于 2016-9-7 09:52:32 | 显示全部楼层 |阅读模式
  1. #ifndef __BSP_LED_
  2. #define __BSP_LED_
  3.
  4. #include <MM32x103.h> // 这个换成STM32的库文件就行
  5. #include "type.h"  // 这个文件就是重定义了一些数据类型,博客里面有
  6.
  7. //==================================================================================
  8. #define LED1_RUN_GRP         GPIOC
  9. #define LED1_RUN_IDX          GPIO_Pin_6
  10. #define LED1_RUN_OFF()       GPIO_ResetBits(LED1_RUN_GRP, LED1_RUN_IDX)
  11. #define LED1_RUN_ON()        GPIO_SetBits(LED1_RUN_GRP, LED1_RUN_IDX)
  12. #define LED1_RUN_IS_OFF()  GPIO_ReadOutputDataBit(LED1_RUN_GRP, LED1_RUN_IDX)
  13.
  14. #define LED2_RUN_GRP         GPIOA
  15. #define LED2_RUN_IDX          GPIO_Pin_11
  16. #define LED2_RUN_OFF()       GPIO_ResetBits(LED2_RUN_GRP, LED2_RUN_IDX)
  17. #define LED2_RUN_ON()        GPIO_SetBits(LED2_RUN_GRP, LED2_RUN_IDX)
  18. #define LED2_RUN_IS_OFF()  GPIO_ReadOutputDataBit(LED2_RUN_GRP, LED2_RUN_IDX)
  19.
  20. #define LED3_RUN_GRP         GPIOA
  21. #define LED3_RUN_IDX          GPIO_Pin_12
  22. #define LED3_RUN_OFF()       GPIO_ResetBits(LED3_RUN_GRP, LED3_RUN_IDX)
  23. #define LED3_RUN_ON()        GPIO_SetBits(LED3_RUN_GRP, LED3_RUN_IDX)
  24. #define LED3_RUN_IS_OFF()  GPIO_ReadOutputDataBit(LED3_RUN_GRP, LED3_RUN_IDX)
  25. //==================================================================================
  26. #define LED_COUNT   3 // LED个数自己定义
  27.
  28. typedef enum
  29. {
  30.     RED   = 0x04,
  31.     GREEN = 0x02,
  32.     BLUE  = 0x01
  33. } led_t;
  34.
  35. typedef struct
  36. {
  37.     GPIO_TypeDef *GPIOx;
  38.     uint32_t pos;
  39. } led_port_t;
  40.
  41. //==================================================================================
  42. void GPIOConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin, GPIOMode_TypeDef GPIO_Mode);
  43. void LEDConfig((uint8_t value) // value:1/2/4 --- RED GREEN BLUE
  44. void LEDSet(uint8_t value);
  45. void LEDReset(uint8_t value);
  46. void LEDToggle(uint8_t value);
  47.
  48. #endif /* __BSP_LED_ */
  1. #include "bsp_led.h"
  2.
  3. static led_port_t led_port[LED_COUNT] =
  4. {
  5.     {LED1_RUN_GRP, LED1_RUN_IDX}, /*蓝灯*/
  6.     {LED2_RUN_GRP, LED2_RUN_IDX}, /*绿灯*/
  7.     {LED3_RUN_GRP, LED3_RUN_IDX}, /*红灯*/
  8. };
  9.
  10. // GPIO配置
  11. void GPIOConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin, GPIOMode_TypeDef GPIO_Mode)
  12. {
  13.     GPIO_InitTypeDef GPIO_InitStructure;//定义GPIO初始化结构体变量
  14.
  15.     // 这个GPIO口需要改的,根据自己情况而定
  16.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOA, ENABLE);  //开启GPIO时钟
  17.
  18.     //配置连接LED的GPIO为推挽输出模式
  19.     GPIO_InitStructure.GPIO_Pin  =  GPIO_Pin;
  20.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  21.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode;
  22.     GPIO_Init(GPIOx, &GPIO_InitStructure);
  23. }
  24.
  25. // LED GPIO配置
  26. void LEDConfig((uint8_t value) // value:1/2/4 --- RED GREEN BLUE
  27. {
  28.     uint8_t i, mask = 1;
  29.
  30.     for(i = 0; i < LED_COUNT; ++i)
  31.     {
  32.         if(value & mask)
  33.         {
  34.             GPIOConfig(led_port[i].GPIOx, led_port[i].pos, GPIO_Mode_Out_PP);
  35.             GPIO_ResetBits(led_port[i].GPIOx, led_port[i].pos);
  36.         }
  37.
  38.         mask <<= 1;
  39.     }
  40. }
  41.
  42. /* 根据参数来打开LED灯 */
  43. void LEDSet(uint8_t value)
  44. {
  45.     uint8_t i, mask = 1;
  46.
  47.     for(i = 0; i < LED_COUNT; ++i)
  48.     {
  49.         if(value & mask)
  50.         {
  51.             GPIO_SetBits(led_port[i].GPIOx, led_port[i].pos);
  52.         }
  53.
  54.         mask <<= 1;
  55.     }
  56. }
  57. /* 根据参数来关闭LED灯 */
  58. void LEDReset(uint8_t value)
  59. {
  60.     uint8_t i, mask = 1;
  61.
  62.     for(i = 0; i < LED_COUNT; ++i)
  63.     {
  64.         if(value & mask)
  65.         {
  66.             GPIO_ResetBits(led_port[i].GPIOx, led_port[i].pos);
  67.         }
  68.
  69.         mask <<= 1;
  70.     }
  71. }
  72.
  73. // 取反
  74. void LEDToggle(uint8_t value)
  75. {
  76.     uint8_t i, mask = 1;
  77.
  78.     for(i = 0; i < LED_COUNT; ++i)
  79.     {
  80.         if(value & mask)
  81.         {
  82.             if(GPIO_ReadOutputDataBit(led_port[i].GPIOx, led_port[i].pos) == 0)
  83.             {
  84.                 GPIO_SetBits(led_port[i].GPIOx, led_port[i].pos);
  85.             }
  86.             else
  87.             {
  88.                 GPIO_ResetBits(led_port[i].GPIOx, led_port[i].pos);
  89.             }
  90.         }
  91.
  92.         mask <<= 1;
  93.     }
  94. }
更多分享请关注csdn博客:http://blog.csdn.net/wqx521
发表于 2016-9-7 10:03:49 | 显示全部楼层
不错哦,用数组来存储设备的引脚相关的配置,之前也见过不少程序是这样写的
 楼主| 发表于 2016-9-7 10:10:29 | 显示全部楼层
这个拓展性还是蛮不错的,我就一直这么再用,个人觉得更加直观。封装GPIO口及引脚方便拓展。
发表于 2016-9-7 11:16:58 | 显示全部楼层
666666,看来动手能力不错啊
 楼主| 发表于 2016-9-7 11:56:03 | 显示全部楼层
落花笑彷徨ㄟ 发表于 2016-9-7 11:16
666666,看来动手能力不错啊
多看多练。你也可以的。
发表于 2016-9-7 14:01:40 | 显示全部楼层
不错  不错
 楼主| 发表于 2016-9-7 16:58:35 | 显示全部楼层
,没事瞎写写。
发表于 2016-9-7 17:41:38 | 显示全部楼层
能调试吗
 楼主| 发表于 2016-9-7 20:41:44 | 显示全部楼层
这个我调试过了的,写个main,测试一下就知道了。把IO口引脚换一下就行了。
GMT+8, 2026-10-4 08:03 , Processed in 0.040324 second(s), 24 queries , Gzip On.
