查看: 21781|回复: 3
求助,ADC+DMA数据搬运不正常
发表于 2018-3-29 17:52:23 | 显示全部楼层 |阅读模式
源码:
main():
TIM3_PWM_Init(2500-1,108000-1);     //108M/108=1MμļÆêyÆμÂ꣬×Ô¶ˉÖØ×°ÔØÎa500£¬ÄÇÃ′PWMÆμÂêÎa1M/500=2kHZ
                MYDMA_Config();
                MY_ADC_Init();                  //3õê¼»ˉADC1í¨μà5
                while(1){
                                LCD_ShowxNum(30,50,uhADCxConvertedValue1,4,16,0X80);    //ÏÔê¾μçÑ1ÖμμÄÕûêy2¿·Ö£¬3.1111μÄ»°£¬Õaàï¾íêÇÏÔê¾3
                                printf("%d\t",uhADCxConvertedValue);
ADC:
void MY_ADC_Init(void)
    ADC1_Handler.Instance=ADC1;
    ADC1_Handler.Init.ClockPrescaler=ADC_CLOCK_SYNC_PCLK_DIV4;   //4·ÖÆμ£¬ADCCLK=PCLK2/4=108/4=27MHZ
    ADC1_Handler.Init.Resolution=ADC_RESOLUTION_12B;             //12λÄ£ê½
                ADC1_Handler.Init.ScanConvMode=DISABLE;                      //·Çé¨ÃèÄ£ê½
                ADC1_Handler.Init.ContinuousConvMode=ENABLE;                //1رÕá¬Dø×a»»
                ADC1_Handler.Init.DiscontinuousConvMode=DISABLE;             //½ûÖ12»á¬Dø2éÑùÄ£ê½
                ADC1_Handler.Init.NbrOfDiscConversion=0;                     //2»á¬Dø2éÑùí¨μàêyÎa0
                ADC1_Handler.Init.ExternalTrigConv=ADC_EXTERNALTRIGCONV_T3_CC4;       //T3_CC4′¥·¢
                ADC1_Handler.Init.ExternalTrigConvEdge=ADC_EXTERNALTRIGCONVEDGE_RISING;//ê1óÃèí¼t′¥·¢
                ADC1_Handler.Init.NbrOfConversion=1;                         //1¸ö×a»»Ôú1æÔòDòáDÖD ò2¾íêÇÖ»×a»»1æÔòDòáD1
    ADC1_Handler.Init.DataAlign=ADC_DATAALIGN_RIGHT;             //óò¶ÔÆë
          ADC1_Handler.Init.DMAContinuousRequests=ENABLE;             //1رÕDMAÇëÇó
    ADC1_Handler.Init.EOCSelection=ENABLE;                      //1رÕEOCÖD¶Ï
    HAL_ADC_Init(&ADC1_Handler);
    ADC1_ChanConf.Channel=ADC_CHANNEL_5;                                   //í¨μà
    ADC1_ChanConf.Rank=1;                                       //1¸öDòáD
    ADC1_ChanConf.SamplingTime=ADC_SAMPLETIME_480CYCLES;        //2éÑùê±¼ä
    ADC1_ChanConf.Offset=0;
    HAL_ADC_ConfigChannel(&ADC1_Handler,&ADC1_ChanConf);        //í¨μàÅäÖà       //3õê¼»ˉ
                HAL_ADC_Start_DMA(&ADC1_Handler, (uint32_t*)&uhADCxConvertedValue, 1);
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* AdcHandle)
  /* Turn LED1 on: Transfer process is correct */
                LED1(0);
                delay_ms(300);
                LED1(1);
                z=(u32)HAL_ADC_GetValue(&ADC1_Handler);
                LCD_ShowString(30,150,200,16,16,"ADC_GetValue");
                LCD_ShowxNum(200,150,z,5,16,0X80);    //ÏÔê¾μçÑ1ÖμμÄÕûêy2¿·Ö£¬3.1111μÄ»°£¬Õaàï¾íêÇÏÔê¾3
                LCD_ShowString(30,180,200,16,16,"DMA_GetValue");
                LCD_ShowxNum(200,180,uhADCxConvertedValue1,5,16,0X80);    //ÏÔê¾μçÑ1ÖμμÄÕûêy2¿·Ö£¬3.1111μÄ»°£¬Õaàï¾íêÇÏÔê¾3
DMA:
void MYDMA_Config(void)
    __HAL_RCC_DMA2_CLK_ENABLE();//DMA2ê±Öóê1Äü
    __HAL_LINKDMA(&ADC1_Handler,DMA_Handle,ADC1DMA_Handler);    //½«DMAóëUSART1áaÏμÆeà′(·¢ËíDMA)
    //Tx DMAÅäÖÃ
    ADC1DMA_Handler.Instance=DMA2_Stream0;                            //êy¾Yá÷Ñ¡Ôñ
    ADC1DMA_Handler.Init.Channel=DMA_CHANNEL_0;                        //í¨μàÑ¡Ôñ
    ADC1DMA_Handler.Init.Direction=DMA_PERIPH_TO_MEMORY;             //′æ′¢Æ÷μ½íaéè
    ADC1DMA_Handler.Init.PeriphInc=DMA_PINC_DISABLE;                 //íaéè·ÇÔöá¿Ä£ê½
    ADC1DMA_Handler.Init.MemInc=DMA_MINC_ENABLE;                     //′æ′¢Æ÷Ôöá¿Ä£ê½
    ADC1DMA_Handler.Init.PeriphDataAlignment=DMA_PDATAALIGN_WORD;    //íaéèêy¾Y3¤¶è:8λ
    ADC1DMA_Handler.Init.MemDataAlignment=DMA_PDATAALIGN_WORD;       //′æ′¢Æ÷êy¾Y3¤¶è:8λ
    ADC1DMA_Handler.Init.Mode=DMA_NORMAL;                            //íaéèá÷¿ØÄ£ê½
    ADC1DMA_Handler.Init.Priority=DMA_PRIORITY_HIGH;               //ÖDμèóÅÏè¼¶
    ADC1DMA_Handler.Init.FIFOMode=DMA_FIFOMODE_DISABLE;
    ADC1DMA_Handler.Init.FIFOThreshold=DMA_FIFO_THRESHOLD_HALFFULL;
    ADC1DMA_Handler.Init.MemBurst=DMA_MBURST_SINGLE;                 //′æ′¢Æ÷í»·¢μ¥′Î′«êä
    ADC1DMA_Handler.Init.PeriphBurst=DMA_PBURST_SINGLE;              //íaéèí»·¢μ¥′Î′«êä
    HAL_DMA_DeInit(&ADC1DMA_Handler);
    HAL_DMA_Init(&ADC1DMA_Handler);
                HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 0, 0);
                HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn);
void DMA2_Stream0_IRQHandler(void){
                        LED0(0);
                        delay_ms(300);
                        LED0(1);
                        HAL_DMA_IRQHandler(&ADC1DMA_Handler);
这里ADC的数据是正常的,但是DMA搬运后的数始终为0,大约每个十个数据有一个是正常的,请问下是DMA哪里配置错了吗?
发表于 2018-3-30 08:40:26 | 显示全部楼层
可以直接按例程来,例程的adc是用DMA的
 楼主| 发表于 2018-3-30 09:22:29 | 显示全部楼层
选择问题是DMA搬运后读取的数据都为0;ADC正常,学习啊
 楼主| 发表于 2018-3-31 22:53:18 | 显示全部楼层
这问题没人能解吗?
GMT+8, 2026-11-22 11:26 , Processed in 0.044765 second(s), 24 queries , Gzip On.
