查看: 17844|回复: 7
检测IO口高低电平,控制LED灯点亮
发表于 2018-6-13 14:33:04 | 显示全部楼层 |阅读模式
请教什么问题!??
#include "stm32f10x.h"
#include "bsp_led.h"
#include "bsp_key.h"
void Delay(uint32_t Count)
        for(; Count != 0; Count--);
        /* LED ¶Ë¿ú3õê¼»ˉ */
        LED_GPIO_Config();
        Key_GPIO_Config();
        while (1)
                                if( GPIO_ReadInputDataBit(KEY1_GPIO_PORT,KEY1_GPIO_PIN        ) == 1 )
                        GPIO_ResetBits(LED1_GPIO_PORT, LED1_GPIO_PIN);
      else  {GPIO_SetBits(LED1_GPIO_PORT, LED1_GPIO_PIN);}
 楼主| 发表于 2018-6-13 14:34:37 | 显示全部楼层
#include "./key/bsp_key.h"
void Key_GPIO_Config(void)
        /*¿aÆô°′¼ü¶Ë¿úμÄê±Öó*/
        RCC_APB2PeriphClockCmd(KEY1_GPIO_CLK|KEY2_GPIO_CLK,ENABLE);
        //Ñ¡Ôñ°′¼üμÄòy½Å
        GPIO_InitStructure.GPIO_Pin = KEY1_GPIO_PIN;
        // éèÖð′¼üμÄòy½ÅÎa¸¡¿Õêäèë
        //ê1óýá11ìå3õê¼»ˉ°′¼ü
        GPIO_Init(KEY1_GPIO_PORT, &GPIO_InitStructure);
        //Ñ¡Ôñ°′¼üμÄòy½Å
        GPIO_InitStructure.GPIO_Pin = KEY2_GPIO_PIN;
        //éèÖð′¼üμÄòy½ÅÎa¸¡¿Õêäèë
        GPIO_Init(KEY2_GPIO_PORT, &GPIO_InitStructure);
 楼主| 发表于 2018-6-13 14:35:06 | 显示全部楼层
#ifndef __KEY_H
#define        __KEY_H
//  òy½Å¶¨òå
#define    KEY1_GPIO_CLK     RCC_APB2Periph_GPIOA
#define    KEY1_GPIO_PORT    GPIOA
#define    KEY1_GPIO_PIN                 GPIO_Pin_7
#define    KEY2_GPIO_CLK     RCC_APB2Periph_GPIOD
#define    KEY2_GPIO_PORT    GPIOD
#define    KEY2_GPIO_PIN                  GPIO_Pin_15
/** °′¼ü°′ϱêÖÃoê
        *  °′¼ü°′ÏÂÎa¸ßμçÆ½£¬éèÖà KEY_ON=1£¬ KEY_OFF=0
        *  èô°′¼ü°′ÏÂÎaμíμçÆ½£¬°ÑoêéèÖÃ3éKEY_ON=0 £¬KEY_OFF=1 ¼′¿é
#define KEY_ON             1
#define KEY_OFF           0
void Key_GPIO_Config(void);
uint8_t GPIO_ReadInputDataBit(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin);
#endif /* __KEY_H */
 楼主| 发表于 2018-6-13 14:35:44 | 显示全部楼层
void LED_GPIO_Config(void)
                /*¶¨òåò»¸öGPIO_InitTypeDefààDíμĽá11ìå*/
                /*¿aÆôLEDÏà1ØμÄGPIOíaéèê±Öó*/
                RCC_APB2PeriphClockCmd( LED1_GPIO_CLK , ENABLE);
                /*Ñ¡Ôñòa¿ØÖÆμÄGPIOòy½Å*/
                GPIO_InitStructure.GPIO_Pin = LED1_GPIO_PIN;
                /*éèÖÃòy½ÅÄ£ê½Îaí¨óÃíÆíìêä3ö*/
                /*éèÖÃòy½ÅËùÂêÎa50MHz */
                /*μ÷óÿaoˉêy£¬3õê¼»ˉGPIO*/
                GPIO_Init(LED1_GPIO_PORT, &GPIO_InitStructure);
                /* ĬèÏ1رÕled1μÆ        */
 楼主| 发表于 2018-6-13 14:36:09 | 显示全部楼层
#ifndef __LED_H
#define        __LED_H
#define LED1_GPIO_PORT            GPIOB                                      /* GPIO¶Ë¿ú */
#define LED1_GPIO_CLK             RCC_APB2Periph_GPIOB                /* GPIO¶Ë¿úê±Öó */
#define LED1_GPIO_PIN                GPIO_Pin_9                                /* ᬽóμ½SCLê±ÖóÏßμÄGPIO */
//#define ON    0
//#define OFF  1
//#define  LED1(a)   if(a) \
//                     GPIO_SetBits(LED1_GPIO_PORT, LED1_GPIO_PIN);\
//               GPIO_ResetBits(LED1_GPIO_PORT, LED1_GPIO_PIN);
void LED_GPIO_Config(void);
#endif /* __LED_H */
 楼主| 发表于 2018-6-13 14:39:22 | 显示全部楼层
情况如附件,请各大神帮忙看看
点亮LED灯.rar
4.25 MB, 下载次数: 478
发表于 2018-6-13 14:54:30 | 显示全部楼层
直接对照野火的按键例程就好了
 楼主| 发表于 2018-6-13 16:14:12 | 显示全部楼层
笑你像狗 发表于 2018-6-13 14:54
直接对照野火的按键例程就好了
按键没问题噢,开关不行呢
GMT+8, 2026-11-22 09:10 , Processed in 0.060754 second(s), 27 queries , Gzip On.
