查看: 18895|回复: 7
新人求助关于固件库点亮LED流水灯形式
发表于 2018-8-31 11:29:06 | 显示全部楼层 |阅读模式
大家好,刚开始学习STM32F103,看到固件库点亮LED,想完成作业流水灯形式,视频提升开启红灯要关闭其他灯,所以我重新定义了LED1 LED2 LED3 红绿蓝灯的开启是这3个灯的组合。代码如下,编译不了。
BH-103.zip
3.69 KB, 下载次数: 369
代码
 楼主| 发表于 2018-8-31 11:30:06 | 显示全部楼层
代码没传好 重新传下
 楼主| 发表于 2018-8-31 11:33:37 | 显示全部楼层
int main (void)
        //来到这里的时候。系统的时钟已经被配置成了72M
        LED_GPIO_Config();
        while(1){
    LED_G(ON);
                Delay(0xFFFFFF);
    LED_B(ON);
                Delay(0xFFFFFF);
                LED_R(ON);
                Delay(0xFFFFFF);
 楼主| 发表于 2018-8-31 11:33:58 | 显示全部楼层
void LED_GPIO_Config(void)
        RCC_APB2PeriphClockCmd(LED_1_GPIO_CLK,ENABLE);
        GPIO_InitTypeDef  GPIO_InitStruct;
        GPIO_InitStruct.GPIO_Pin = LED_1_GPIO_PIN;
  GPIO_InitStruct.GPIO_Mode=GPIO_Mode_Out_PP;
        GPIO_InitStruct.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_Init(LED_1_GPIO_PORT, &GPIO_InitStruct);
        RCC_APB2PeriphClockCmd(LED_2_GPIO_CLK,ENABLE);
        GPIO_InitStruct.GPIO_Pin = LED_2_GPIO_PIN;
        GPIO_Init(LED_2_GPIO_PORT, &GPIO_InitStruct);
        RCC_APB2PeriphClockCmd(LED_3_GPIO_CLK,ENABLE);
        GPIO_InitStruct.GPIO_Pin = LED_3_GPIO_PIN;
        GPIO_Init(LED_3_GPIO_PORT, &GPIO_InitStruct);
 楼主| 发表于 2018-8-31 11:34:21 | 显示全部楼层
#ifndef _BSP_LED_H
#define _BSP_LED_H
#include "stm32f10x.h"
#define LED_2_GPIO_PIN    GPIO_Pin_1
#define LED_2_GPIO_PORT   GPIOB
#define LED_2_GPIO_CLK    RCC_APB2Periph_GPIOB
#define LED_1_GPIO_PIN    GPIO_Pin_0
#define LED_1_GPIO_PORT   GPIOB
#define LED_1_GPIO_CLK    RCC_APB2Periph_GPIOB
#define LED_3_GPIO_PIN    GPIO_Pin_5
#define LED_3_GPIO_PORT   GPIOB
#define LED_3_GPIO_CLK    RCC_APB2Periph_GPIOB
#define ON   1
#define OFF  0
//\C语言续行符,要求后面不能有任何东西
#define LED_2(a)    if(a) \
        GPIO_ResetBits(LED_2_GPIO_PORT, LED_2_GPIO_PIN);\
                       else\
  GPIO_SetBits(LED_2_GPIO_PORT, LED_2_GPIO_PIN);
#define LED_1(a)    if(a) \
        GPIO_ResetBits(LED_1_GPIO_PORT, LED_1_GPIO_PIN);\
                       else\
  GPIO_SetBits(LED_1_GPIO_PORT, LED_1_GPIO_PIN);
#define LED_3(a)    if(a) \
        GPIO_ResetBits(LED_3_GPIO_PORT, LED_3_GPIO_PIN);\
                       else\
  GPIO_SetBits(LED_3_GPIO_PORT, LED_3_GPIO_PIN);
#define LED_G(ON) ((LED_1(ON)&& LED_2(OFF)&&LED_3(OFF))
#define LED_B(ON) ((LED_1(OFF)&& LED_2(ON)&&LED_3(OFF))
#define LED_R(ON) ((LED_1(OFF)&& LED_2(OFF)&&LED_3(ON))
void LED_GPIO_Config(void);
#endif
 楼主| 发表于 2018-8-31 11:34:57 | 显示全部楼层
主要就是上面3个 大神帮我解惑下
 楼主| 发表于 2018-8-31 13:57:37 | 显示全部楼层
问题已经解决了
发表于 2018-9-1 09:07:41 | 显示全部楼层
怎么解决的,把原因写下来,让其他同学了解一下
GMT+8, 2026-11-22 10:38 , Processed in 0.048616 second(s), 27 queries , Gzip On.
