查看: 27111|回复: 1
根据压力信号控制舵机
发表于 2019-5-16 20:38:28 | 显示全部楼层 |阅读模式
那位大佬帮忙看下程序
int main()
u8 servo_fx=1,i,j,k;
u16 servo_dt=50;
float Weight = 0;
SysTick_Init(168);
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);  //ÖжÏÓÅÏȼ¶·Ö×é ·Ö2×é
LED_Init();
TIM14_CH1_PWM_Init(1999,719);
Init_Hx711();
delay_ms(2000);
Get_Maopi();
delay_ms(100);
   Weight = Get_Weight();
   Weight = (float)Weight/1000.0f;
   printf("%0.3f kg\n",Weight); //´®¿ÚÏÔÊ¾ÖØÁ¿
  i=printf("%0.3f kg\n",Weight);//¼Ç¼µÚÒ»´ÎµÄ³ÆÖØÖµ
   delay_ms(1000);               //ÑÓʱ1Ãë
   j=printf("%0.3f kg\n",Weight);//¼Ç¼µÚ¶þ´Î³ÆÖØÖµ
  k=i/j;                        //Á½ÕßÏà±È½Ï
  if(servo_fx==1)               //Èç¹û¶æ»ú·½ÏòΪ1
     if(k<0.9)                  //&Egrave;&ccedil;&sup1;&ucirc;±&Egrave;&Ouml;&micro;&ETH;&iexcl;&Oacute;&Uacute;0.9
      servo_dt--;              //&para;&aelig;&raquo;ú&frac12;&Ccedil;&para;&Egrave;&sup2;&raquo;&para;&Iuml;&frac14;&otilde;&ETH;&iexcl;
     else                       //·&ntilde;&Ocirc;ò
      servo_dt=servo_dt;       //&para;&aelig;&raquo;ú&frac12;&Ccedil;&para;&Egrave;&sup2;&raquo;±&auml;
  else                          //&Egrave;&ccedil;&sup1;&ucirc;&para;&aelig;&raquo;ú·&frac12;&Iuml;ò&sup2;&raquo;&Icirc;&ordf;1
    servo_dt=200;               //&para;&aelig;&raquo;ú&frac12;&Ccedil;&para;&Egrave;&Icirc;&ordf;135&iexcl;&atilde;
  TIM_SetCompare1(TIM14,servo_dt); //&frac12;&laquo;servo_dt&Ouml;&micro;&cedil;&sup3;&Oacute;è&Iacute;¨&micro;&Agrave;14
  delay_ms(3000);
表达有问题,希望指点
发表于 2019-5-17 09:04:51 | 显示全部楼层
不是表达有问题,你什么都没表达……
GMT+8, 2026-11-22 10:38 , Processed in 0.038971 second(s), 24 queries , Gzip On.
