查看: 28455|回复: 1
新手求助野火霸道核心板的开关灯问题
发表于 2020-1-5 18:12:03 | 显示全部楼层 |阅读模式
    *(unsigned int *)0x40021018=0x00000008; //开时钟
    *(unsigned int *)0x40010c00=0x44444441; //pb0推挽输出模式
    *(unsigned int *)0x40010c0c=0x00000000;//开灯
    int x=0;
    while(x<100)
        *(unsigned int *)0x40010c0c =0xffffffff;//关灯
        x++;//如果把这句注释后灯就关不掉了
    while(1);
//以上是野火霸道核心板上运行,当把x++那一句注释后,while循环就变成了无限循环,灯就关不掉了,不知道为什么,大家帮我看看,谢谢!
 楼主| 发表于 2020-1-6 19:53:23 | 显示全部楼层
该问题已解决,对端口地址的操作得加上volatile以防止编译器优化。写了一段两个按键控制两个led灯的代码,仅供参考。
    *(volatile unsigned int *)0x40021018=0x0000001c; //开时钟
    *(volatile unsigned int *)0x40010c00=0x44444411; //PB0推挽输出模式
    *(volatile unsigned int *)0x40010c0c=0xffffffff;//关灯
    *(volatile unsigned int *)0x40010800=0x44444444;//a口输入模式
    *(volatile unsigned int *)0x40011000=0x44444444;//c口输入模式
        if (*(volatile unsigned int *)0x40010808 & 0x0001) //按键1按下(PA0)
        *(volatile unsigned int *)0x40010c0c &=0xfffffffe;//开PB0口led
        *(volatile unsigned int *)0x40010c0c |=0x00000001;//关PB0口led
        if (*(volatile unsigned int *)0x40011008 & 0x2000)//按键2按下
        *(volatile unsigned int *)0x40010c0c &=0xfffffffd;//开PB1口led
        *(volatile unsigned int *)0x40010c0c |=0x00000002;//关PB1口led
GMT+8, 2026-11-22 08:55 , Processed in 0.035957 second(s), 24 queries , Gzip On.
