查看: 1715|回复: 1
[求助] 鲁班猫RV1106开发板 扩展GPIO5基地址
发表于 2026-5-14 21:48:50 | 显示全部楼层 |阅读模式
老师好!
      请教个问题:[野火]《快速使用手册-基于LubanCat-RV110x系列板卡》_20250312.pdf中Page 98描述扩展的GPIO5基地址为272:
      “ ... 板卡上除了主控芯片原生IO,也使用i2c扩展gpio(GPIO5),使用拓展IO的计算方式不一样,基地址是272,因此基于GPIO5的引脚公式需要加上基地址,...."
      请问基地址272是在sdk的什么地方定义的?
 楼主| 发表于 2026-5-16 09:27:18 | 显示全部楼层
找到扩展GPIO5接口的基地址定义了:
1、在sysdrv/source/kernel/drivers/gpio/gpiolib.c中的gpiochip_find_base(int ngpio)中增加调试日志:
static int gpiochip_find_base(int ngpio)
        struct gpio_device *gdev;
        int base = ARCH_NR_GPIOS - ngpio;
        pr_info("[GPIO DEBUG] gpiochip_find_base() called, ngpio=%d, ARCH_NR_GPIOS=%d, initial base=%d\n",
                ngpio, ARCH_NR_GPIOS, base);
        if (list_empty(&gpio_devices)) {
                pr_info("[GPIO DEBUG] gpio_devices list is empty, returning base=%d\n", base);
                if (gpio_is_valid(base))
                        return base;
                        return -ENOSPC;
        pr_info("[GPIO DEBUG] Scanning existing gpio_devices list:\n");
        list_for_each_entry_reverse(gdev, &gpio_devices, list) {
                pr_info("[GPIO DEBUG]   gdev->base=%d, gdev->ngpio=%d, gdev->label=%s\n",
                        gdev->base, gdev->ngpio, gdev->label ? gdev->label : "NULL");
                /* found a free space? */
                if (gdev->base + gdev->ngpio <= base) {
                        pr_info("[GPIO DEBUG]   Found free space before this chip, breaking\n");
                        break;
                } else {
                        /* nope, check the space right before the chip */
                        pr_info("[GPIO DEBUG]   Overlap detected, moving base from %d to %d\n",
                                base, gdev->base - ngpio);
                        base = gdev->base - ngpio;
        if (gpio_is_valid(base)) {
                pr_info("[GPIO DEBUG] gpiochip_find_base() succeeded, returning base=%d\n", base);
                return base;
        } else {
                pr_err("[GPIO DEBUG] gpiochip_find_base() failed, cannot find free range\n");
                return -ENOSPC;
在日志中可以追踪到如下输出:
[    0.215682] [GPIO DEBUG] gpiochip_find_base() called, ngpio=16, ARCH_NR_GPIOS=288, initial base=272
[    0.215699] [GPIO DEBUG] Scanning existing gpio_devices list:
[    0.215707] [GPIO DEBUG]   gdev->base=128, gdev->ngpio=24, gdev->label=gpio4
[    0.215713] [GPIO DEBUG]   Found free space before this chip, breaking
[    0.215718] [GPIO DEBUG] gpiochip_find_base() succeeded, returning base=272
2、追踪ARCH_NR_GPIOS定义:
  在sysdrv/source/kernel/include/asm-generic/gpio.h中追踪到下面定义:
#ifndef ARCH_NR_GPIOS
#if defined(CONFIG_ARCH_NR_GPIO) && CONFIG_ARCH_NR_GPIO > 0
#define ARCH_NR_GPIOS CONFIG_ARCH_NR_GPIO
#else
#define ARCH_NR_GPIOS                512
#endif
#endif
3.在sysdrv/source/objs_kernel/.config 追踪到:
  CONFIG_ARCH_NR_GPIO=288
完美解决。
GMT+8, 2026-10-18 03:26 , Processed in 0.119720 second(s), 25 queries , Gzip On.
