查看: 29048|回复: 0
[emWin] emwin自定义消息的问题
发表于 2014-9-17 11:23:07 | 显示全部楼层 |阅读模式
自己定义了一个消息,然后在出函数里面每1s发送一次消息,再调用WM_InvalidateWindow(hWin);执行WM_PAINT改变窗体的颜色,为什么颜色没有被改变。感觉是消息没有发送过来。求大神帮忙解答。
#include <stddef.h>
#include "GUI.h"
#include "DIALOG.h"
#include "WM.h"
*       static data
#define WM_UPDATE WM_USER+1
GUI_COLOR _acColor[3] = {GUI_BLUE,GUI_RED,GUI_YELLOW};
static char ucBackColor;
void PaintDialog(WM_MESSAGE *pMsg)
WM_HWIN hWin = pMsg->hWin;
GUI_SetBkColor(_acColor[ucBackColor]);
GUI_Clear();
*       Dialog resource
* This table conatins the info required to create the dialog.
* It has been created by ucGUIbuilder.
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
    { FRAMEWIN_CreateIndirect, "Caption",   0,                0,  0,  320,240,FRAMEWIN_CF_MOVEABLE,0},
    { BUTTON_CreateIndirect,   "BUTTON2",   GUI_ID_BUTTON0,   162,36, 89, 51, 0,0},
    { BUTTON_CreateIndirect,   "BUTTON1",   GUI_ID_BUTTON0,   33, 36, 90, 51, 0,0}
**      FunctionName:void InitDialog(WM_MESSAGE * pMsg)
**      Function: to initialize the Dialog items
**      call this function in _cbCallback --> WM_INIT_DIALOG
    //FRAMEWIN
    FRAMEWIN_AddCloseButton(hWin, FRAMEWIN_BUTTON_RIGHT, 0);
    FRAMEWIN_AddMaxButton(hWin, FRAMEWIN_BUTTON_RIGHT, 1);
    FRAMEWIN_AddMinButton(hWin, FRAMEWIN_BUTTON_RIGHT, 2);
ucBackColor=0;
*       Dialog callback routine
static void _cbCallback(WM_MESSAGE * pMsg)
    int NCode, Id;
    switch (pMsg->MsgId)
  case WM_UPDATE:
   ucBackColor++;
   if(ucBackColor == 3)
    ucBackColor = 0;
  break;
  case WM_PAINT:
   PaintDialog(pMsg);
   break;
        case WM_INIT_DIALOG:
            InitDialog(pMsg);
            break;
        case WM_KEY:
            switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key)
                case GUI_KEY_ESCAPE:
                    GUI_EndDialog(hWin, 1);
                    break;
                case GUI_KEY_ENTER:
                    GUI_EndDialog(hWin, 0);
                    break;
            break;
        case WM_NOTIFY_PARENT:
            Id = WM_GetId(pMsg->hWinSrc);
            NCode = pMsg->Data.v;
            switch (Id)
                case GUI_ID_OK:
                    if(NCode==WM_NOTIFICATION_RELEASED)
                    break;
                case GUI_ID_CANCEL:
                    break;
            break;
        default:
            WM_DefaultProc(pMsg);
*       MainTask
void MainTask(void)
unsigned char i;
WM_HWIN hDlg;
    GUI_Init();
    WM_SetDesktopColor(GUI_WHITE);      /* Automacally update desktop window */
    WM_SetCreateFlags(WM_CF_MEMDEV);  /* Use memory devices on all windows to avoid flicker */
    hDlg = GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);
  WM_SendMessageNoPara(WM_GetClientWindow(hDlg),WM_UPDATE);
  GUI_Delay(1000);
GMT+8, 2026-10-30 21:37 , Processed in 0.038100 second(s), 24 queries , Gzip On.
