查看: 28464|回复: 2
请高手指教,谢谢
发表于 2015-4-10 10:59:12 | 显示全部楼层 |阅读模式
小弟刚弄stm32,有问题请教。光电开关通时为高电平,被遮挡时为低电平,想通过引脚高低电平的检测控制其他引脚高低电平的输出来点亮灯,在光电开关不被遮挡时,PC13输出低电平,被遮挡时PC13输出高电平以点亮小灯,不知道哪里出问题了,请各位大虾看看,谢谢。
LED.C
#include "led.h"
* oˉêyÃû£oLED_GPIO_Config
* Ãèêö  £oÅäÖÃLEDóÃμ½μÄI/O¿ú
* êäèë  £oÎT
* êä3ö  £oÎT
void LED_GPIO_Config(void)
        /*¶¨òåò»¸öGPIO_InitTypeDefààDíμĽá11ìå*/
        /*¿aÆôGPIOCμÄíaéèê±Öó*/
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC, ENABLE);
        /*Ñ¡Ôñòa¿ØÖÆμÄGPIOCòy½Å*/
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
        /*éèÖÃòy½ÅÄ£ê½Îaí¨óÃíÆíìêä3ö*/
        /*éèÖÃòy½ÅËùÂêÎa50MHz */
        /*μ÷óÿaoˉêy£¬3õê¼»ˉGPIOC*/
        /* 1رÕËùóDledμÆ        */
//        GPIO_SetBits(GPIOC, GPIO_Pin_13);
led.h的
#ifndef __LED_H
#define        __LED_H
#include "stm32f10x.h"
/* the macro definition to trigger the led on or off
* 1 - off
- 0 - on
//#define ON  0
//#define OFF 1
////′ø2Îo꣬¿éòÔÏñÄúáaoˉêyò»Ñùê1óÃ
//#define LED1(a)        if (a)        \
//                                        GPIO_SetBits(GPIOC,GPIO_Pin_13);\
//                                        else                \
//                                        GPIO_ResetBits(GPIOC,GPIO_Pin_13)
void LED_GPIO_Config(void);
#endif /* __LED_H */
main.c的
#include "led.h"
u8 ReadValue;
void OPT_GPIO_Config(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  //GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        // portstatus == GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_7);
        ReadValue = GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_7);
//void Delay(__IO u32 nCount);
* oˉêyÃû£omain
* Ãèêö  £oÖ÷oˉêy
* êäèë  £oÎT
* êä3ö  £oÎT
        OPT_GPIO_Config();
        /* LED ¶Ë¿ú3õê¼»ˉ */
        LED_GPIO_Config();
  if (ReadValue)
                GPIO_ResetBits(GPIOC,GPIO_Pin_13);
//void Delay(__IO u32 nCount)         //¼òμ¥μÄÑóê±oˉêy
//        for(; nCount != 0; nCount--);
/******************* (C) COPYRIGHT 2012 WildFire Team *****END OF FILE************/
发表于 2015-4-10 12:58:38 | 显示全部楼层
        OPT_GPIO_Config();
        LED_GPIO_Config();
if (ReadValue)
 楼主| 发表于 2015-4-10 14:51:44 | 显示全部楼层
亽亼 发表于 2015-4-10 12:58
        OPT_GPIO_Config();
谢谢你,解决了我的问题,谢谢啊,小白我很是感谢!!!
GMT+8, 2026-11-18 18:04 , Processed in 0.045108 second(s), 25 queries , Gzip On.
