查看: 2596|回复: 1
[经验\资料] RK3588-Luban5-debain-lite apt update更新时提示证书错误
发表于 2025-4-21 15:22:16 | 显示全部楼层 |阅读模式
  自己从代码中编译出来的debian-lite,发现一直apt-update失败,更换软件源也一样,一直是证书错误如下,网络上要么让改软件源https为http,或者安装ntp或者重新安装Certificate都不太对或者没效果,
Err:1 https://cloud.embedfire.com/mirrors/ebf-debian carp-rk3588 InRelease
  Certificate verification failed: The certificate is NOT trusted. The certificate chain uses not yet valid certificate.  Could not handshake: Error in the certificate verification. [IP: 121.207.229.243 443]
最后发现data -R显示的时间是2024,没有更新到时间的问题
root@lubancat:~# date -R
Mon, 26 Aug 2024 05:07:55 +0800
那就使用ntpdate更新时间
root@lubancat:~# sudo ntpdate time.nist.gov
Mon, 21 Apr 2025 14:14:13 +0800
之后正常update。
GMT+8, 2026-10-18 05:41 , Processed in 0.138603 second(s), 25 queries , Gzip On.
